 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 04/05/2017 Posts: 81 Points: 245 Location: Greece
I have bought the whole lot of the 100 Del Prado Cutty Sark issues from Germany (new and unopened!). Is was an Ebay bargain but the problem is the language. All issues are in German.
Because I don't have the time to translate every issue, can I find anywhere (PDF) the instructions of the English version?
In short, no chance unless you can find someone with an English version that is prepared to copy, Google translate being a possible alternative. DelPrado in its original guise went bust not long after this collection came to its end. The company has since re-started and you could possibly email them to ask the question though it's a long shot. You may also have problem if anything major is missing from the packs.
Thank you,I think google will be my friend :) I didn't know Del Prado shut down. Fortunately enough I checked all the issues and all are sealed and without missing parts. My only worry is some comments I read yesterday about quality issues which cause many problems to the planking process. Next days I will start the translation and then I will see if it is as bad as it sounds.
