Gun ports?????? Options
Allan
#1 Posted : 17 March 2011 19:33:32
Can anyone tell me what the rebate measurement is on the gun ports ????
Allan
#2 Posted : 20 March 2011 07:26:35
i take it from the total lack of response that no one on this forum knows if there is a rebate or not to accommodate the gun port coversBlink Blink Blink Blink Blink Blink Blink Blink
Zeptrader
#3 Posted : 20 March 2011 08:30:54
Have a look at the magazine and Tomicks build you'll find the gun ports are framed, as I'm sure you already know, the gun ports in the official build don't have a recess, for me and a few other have departed from the official build and changed the way the ports are done to give a recess.
How much of a rebate is down to you, but the thickness of the planking of 2mm is how I've measured it.
and also I did a quick search 'gun port recess' and came up with 3 pages.
http://forum.model-space...default.aspx?g=search#0|5
Allan
#4 Posted : 20 March 2011 09:30:19
Hi Zap thanks for thatBigGrin its just that i have double planked and did not know whether to leave a 1mm edge round the gunports Confused Confused Confused
Allan
Zeptrader
#5 Posted : 20 March 2011 09:35:52
I suppose it all depends if your going to have the gun port lids closed or open, if closed then you want the lids to be flush with the hull, which means you will have to have the lids 1mm thick, see what other reckon.
#6 Posted : 20 March 2011 09:49:39
just a few things if you are going to have a rebate(rabbit)1,you decide if a rebate or not,2,as zep says are your gunports open or shut,3,what are the thickness of the ports? we don't know yet.?4. what thickness is your outer planking?
I used the thickness of my outer planking.08mm,to form the rebate.check my build to see if that suits.
#7 Posted : 20 March 2011 23:27:11
just gonna throw a little hand grenade into this discussion... it would appear on the real ship the rebate thickness vary and not just because of the wales. and on that note i will run off BigGrin
This page was generated in 0.109 seconds.
