Ground Crew Options
Mustang
#1 Posted : 04 May 2017 21:14:45
Hi guys, I'm looking to see if there's anyone out there that make 1/24 ground crew.
I'm looking for RAF crew from around the early 1980's.
Looking for about four, I did find some Tamiya Rally crew which I could look at modding.
https://www.amazon.com/e.../B000LFSHI6/rocketfin-20
Built:-. HMS Bounty, RMS Titanic, MP4-23, Flying Scotsman, Aston Martin DB5, Honda CB750, Mustang, R2-D2, Jaguar, DeLorean, Testarossa, Stage Coach plus many plastic kits.
Dry dock no room to display:-. Bismarck, U96.
To build:-
. HMS Hood. HMS Victory. Cutty Sark. SoS, Lancaster bomber. DR1 Triplane. JU-87. Plus many many plastic kits.
#2 Posted : 04 May 2017 21:29:41
Could not find much in the modern type but here are some ww2 that might be possible to convert
http://reedoak.com/#!/1-24/c/18324013/offset=0&sort=normal
Under figures ww2 and also some civillian figures
You might also want to look at some fujimi figures that might be convertable.
Here are 2 item number from ebay to give you an idea
122427310675
302258184141
#3 Posted : 05 May 2017 10:30:05
Hi Mustang
The other source you might find is Scalextric? mechanics and pit crew figures. I think they were around the 1/24 scale.
Robin.
Mustang
#4 Posted : 07 May 2017 09:55:19
Thanks for the info guys.
I did look at the reedoak before, but they would need some work to make them look like rafs. Scalextric didn't even think about them, but the detail doesn't look as good as the tamiya figures.
So I've ordered a set of tamiya mechanics, hopefully I can make them look like rafs.
To build:-
