Issue 19 Greebly- Where does it go? Options
Gast Hypor
#1 Posted : 02 May 2017 09:48:19
I thought I had finished my build until i had a bag left over from issue 19 with one greebly still attached to the sprue. Referring back to the instructions, it states to leave it out until later. Did I miss something?Confused
#2 Posted : 02 May 2017 10:47:09
The greebly from issue 19 goes on the top hull piece that was supplied in issue one. I can't sent you a pictures at the moment but if you look at a reference picture you should be able to see it. You will also find you have a small hole where it fits.
Gast Hypor
#3 Posted : 02 May 2017 11:10:33
Oh, thanks Mark. Do you know which issue had the instructions to fit it?
#4 Posted : 02 May 2017 11:34:21
Off hand no. When I get in this evening I'll have a look or send you a picture of it in place.
#5 Posted : 02 May 2017 13:28:33
The addition of this part is covered in issue 24, you can see in the official build diary
http://forum.buildmillen...n-build-diary-issue-24/
Hope this helps Cool
Gast Hypor
#6 Posted : 02 May 2017 13:33:11
Brilliant- thanks both for your help!Cool
This page was generated in 0.167 seconds.
