16 Pages «<910111213>»
Jonny's Sovereign Options
#201 Posted : 30 April 2017 16:17:55
So pleased to see you back with us all and posting again.
Life has its ways of causing us problems at different times but i am pleased you are feeling at the point were you can now pick up your hobby again.
Your build is looking wonderful and it will be wonderful to see you progressing again with this one.
#202 Posted : 30 April 2017 16:35:54
Good to have you back Jonny, watching with interest Cool
#203 Posted : 30 April 2017 17:40:50
BigGrin Nice to see you back Jonny, onwards and upwards with the buildCool
#204 Posted : 30 April 2017 17:49:23
Great to have you back, looks like you've contracted a more critical eye. LOL
#205 Posted : 30 April 2017 20:51:01
Great to see you back Jonny, you've been missed.... Hope your health is much improved and look forward once again to seeing your build progressing.....Cool Cool
#206 Posted : 30 April 2017 21:02:50
It`s good to see you back and obviously ready to crack on with your Sots.
Cool Cool Cool Cool Cool
Looking forward to seeing your input on the forum.BigGrin
#207 Posted : 30 April 2017 21:07:53
Good to see you back on your build, looking forward to seeing it progress.
#208 Posted : 09 May 2017 06:05:54
Hi Jonny,
Nice to see you back. Looking forward to see your progress.
jonny7england
#209 Posted : 09 May 2017 19:03:13
After my long break from my build, I seem to be missing two parts from the same issue. Does anybody know if I can still buy Issue 53 of SOTS from Deag??? Much obliged...
Unsure
#210 Posted : 09 May 2017 19:31:49
Unsure
Have PM`d an idea.
#211 Posted : 09 May 2017 19:39:01
Hi Jonny, you could try emailing sales@model-space.co.uk. You never know but they may just be able to help.
#212 Posted : 09 May 2017 20:40:39
Unsure
Jonny
Not sure if it would help you but there is a part 53 on ebay at the moment with parts but is a little pricey ay£10.95
Here is the code
401266790762
#213 Posted : 31 August 2017 17:59:19
Jonny
Glad to hear its all moving in the right direction for you.
It can be difficukt to pick up were you left off after a spell away but knowing your great works i am sure it will all go well for you.
#214 Posted : 31 August 2017 20:18:38
Jonny, your last photobucket image is not showing, you'll need to dump photobucket and find a new photoshare site or think about using the fix http://forum.model-space...sts&t=23676&p=3
jonny7england
#215 Posted : 06 September 2017 18:57:31
Hi shipmate...I've been busy fiddling around with my SOTS build tweaking bit here and there and adding some more of the bling to her stern. I am at present on issue 67 where I am having issues with cutting out the holes in the deck bulkheads. A job that I thought would be a breeze until I remembered that I had to cut through wood which is not very workable with a craft knife, then finding the bulkhead strips coming apart near the top of the bulkhead..Curses..With some cussing I am slowly winning though. I am adding just one pic at this point...So, onward and upward me hearties...
Confused Crying
Transit Pic 70.JPG (458kb) downloaded 39 time(s).
jonny7england attached the following image(s):
neon
#216 Posted : 06 September 2017 20:33:35
Hi johnnie
Those ports are very tough to cut out. I used a sanding bit to finally get the job done. Anyway great to see you back. Your build is looking fantastic. Keep up the good work mate.
#217 Posted : 06 September 2017 20:45:56
BigGrin Hi Jonny the stern is looking brilliant Cool Cutting the holes are a real pain , to help stop them splitting out I found running ca glue down the seams helps hold them in place also I used drills in slowly increasing size to hand drill the holes and made up a dowel of the right size with some sandpaper wrapped around it to sand it to the right diameter
Hope this helps rgd Martyn
#218 Posted : 06 September 2017 22:48:14
Hi Jonny, she's coming along beautifully and all credit to your patience.....Cool Cool .. Drilling the holes can be a little dodgy especially at the very top of the bulkheads but Martyn has described the best solution, a dowel that is smaller than the required diameter with find sandpaper glued around it at one end. This method will give you far greater control than any drill bit or file....Cool Cool .. Keep up the good work....
jonny7england
#219 Posted : 09 September 2017 15:01:27
Since Tuesday, (with the help from a fellow Model Space member to whom I will be forever grateful) I have spent quite some time trying to put together my SOTS build diary trying to fit photographs to the words...But, I'm very sad to say that I failed to rescue some of my pictures from a certain photo sharing site which can not be put back into my build diary leaving ugly gaps. Sadly, I have had to ask to have my Victory build diary to be removed all together...But, I shall continue the task of restoring this diary where I can and adding a few new pictures of my recent work on SOTS.
Blink Crying
And to that photo sharing site
Flapper
#220 Posted : 09 September 2017 15:42:38
BigGrin Looking good my friend, lovely job on the gunports Cool
This page was generated in 0.337 seconds.
