21 Pages «<34567>»
maurizio67-mp4/4 build diary Options
maurizio67
#81 Posted : 26 March 2017 18:09:18
maurizio67 attached the following image(s):
#82 Posted : 27 March 2017 06:38:42
Very nice details BigGrin
frah2o
#83 Posted : 27 March 2017 14:25:50
Following the step of this awesome build i just bought the dcals set tyres for mine mp4 from autograph.
I would ask to Maurizio (also to Malc and the other mates tha made this job) how is the right metod to apply the decals tyres.
I must wash or spray the rubber tyres with something?
Thanks in advance
maurizio67
#84 Posted : 27 March 2017 18:44:22
frah2o wrote:
t
noooooooooooooooooooooooBigGrin BigGrin BigGrin
#85 Posted : 27 March 2017 18:56:51
Those rivets look seriously small.Blink
Fiddly to work with I bet, but a nice choice.
Well done.
#86 Posted : 27 March 2017 19:40:57
Lovely details being added, great work Maurizio Cool
maurizio67
#87 Posted : 28 March 2017 06:45:04
put the carbon is becoming a very long process.... Bored
frah2o
#88 Posted : 04 April 2017 10:57:46
Hi Maurizio, i ask you some details about your (awesome) build
I read whole topic to find spec for extra coolant hoses.
When i can get violet hose and braided hose with the plug end? (in the red and green circles)
maurizio67
#89 Posted : 05 April 2017 06:40:51
So larger radiator:
Tapping 0.8 and then switch to a tip 2 mm, fitting insertion aluminum DMADM3094 Combination fitting 4 1.88mm taken from model fitting and baracca.Il 'hex the round hole and then to fill the space that had been created I used the liquid vinyl positioned with the toothpick in order to make uniform and devoid of spaces drilling, once I dried the vinyl I painted with aluminum above the vinyl "always with the toothpick" then I cut about 1.5 mm tube silicone and positioned above the painted vinyl so as to simulate a gasket.
For the small radiator I drilled with a 0.8 mm bit 'attention to the chrome if escapes the tip goodbye ... "and then enter the chrome siding, but now I have seen that there are more but these are of hiroboy; 1:12 Hose Joint Set B - P1119
for the braid tube or modeling cabin or always hiroboy
#90 Posted : 05 April 2017 07:59:16
Great detail with the rivets, Nice work
maurizio67
#91 Posted : 17 April 2017 06:46:00
quite firm, they are not coming to me more packages !!!Cursing Cursing
maurizio67
#92 Posted : 28 April 2017 16:50:33
Now can start work again!
maurizio67
#93 Posted : 29 April 2017 06:17:26
#94 Posted : 29 April 2017 06:37:45
Very neat BigGrin
#95 Posted : 29 April 2017 09:24:39
Such realistic detailing, you are really making a wonderful model.
maurizio67
#96 Posted : 30 April 2017 20:27:52
Thanks !!!!
maurizio67
#97 Posted : 30 April 2017 20:28:56
Thanks !!!!
#98 Posted : 30 April 2017 22:19:19
Nice work on those brake reservoirs, they look suitably dirty.
NSXKid
#99 Posted : 01 May 2017 03:20:44
Awesome detail work. I can't wait to see more from you.
maurizio67
#100 Posted : 01 May 2017 08:06:43
Photography does not show the details in the best nest
21 Pages «<34567>»
