106 Pages «<2627282930>»
#541 Posted : 27 April 2017 07:51:25
I then proceeded to mark out and make a larger hole using a compass cutter. This larger hole is for the main pipework to run through.
#542 Posted : 27 April 2017 07:52:01
Larger hole complete.
#543 Posted : 27 April 2017 07:53:39
All three supports drilled out.
#544 Posted : 27 April 2017 07:58:55
Next step was to mark out and fix bolt heads to the plate that the mast well sits against. Taking my inspiration from Frank Dargies 1/72 build I could determine their locations.
Digging around in my spares box I used M1 bolts [1mm dia] which equates to approx. 2" in real life, which is about right.
This photo shows how small these bolts are.
#545 Posted : 27 April 2017 07:59:55
A close up of the M1 bolt.
#546 Posted : 27 April 2017 08:02:41
Another photo to highlight the small size. I bought these from Scale Hardware a few years ago. Scale Hardware has recently amalgamated with Model Motor Cars, based in Florida.
#547 Posted : 27 April 2017 08:09:34
This photo shows all the holes marked out and drilled on the mast well blanking plate to accept the M1 bolts.
#548 Posted : 27 April 2017 08:10:52
I then fabricated and fixed two runners on the blanking plate to hold the central support.
#549 Posted : 27 April 2017 08:12:24
This photo shows the central support being test fitted into the runners.
#550 Posted : 27 April 2017 08:13:01
From another angle.
#551 Posted : 27 April 2017 08:14:09
This photo shows the first M1 bolt in place.
#552 Posted : 27 April 2017 08:15:07
A close up.
#553 Posted : 27 April 2017 08:15:28
Excellent work as usual, looks stunning. Drool Drool
#554 Posted : 27 April 2017 08:15:52
All M1 bolts completed.
#555 Posted : 27 April 2017 08:17:54
Completed mast well, blanking plate, forward and aft supports fixed in place within No.3 MBT.
#556 Posted : 27 April 2017 08:19:02
Looking aft.
#557 Posted : 27 April 2017 08:20:10
Looking forward.
#558 Posted : 27 April 2017 08:22:42
To simulate the two different sizes of pipework within No.3 MBT I came across the idea of using some plastic sprue I had lying around. Measuring it up then scaling from 1/48 to 1/1, it comes out at around 8" diameter which is about correct for these internal pipes that would transfer water or oil.
#559 Posted : 27 April 2017 08:23:53
This photo shows another sprue tree I used for the pipework.
#560 Posted : 27 April 2017 08:25:18
A photo of the larger and longer of the two pipes. I had to use a bit of filler on the inner radius so that the pipe bend flowed correctly.
Guest (5)
This page was generated in 0.499 seconds.
