24 Pages «<45678>»
L'Hermione Build Options
#101 Posted : 26 April 2017 09:42:29
This is turning out to be a really nice build.
#102 Posted : 26 April 2017 20:14:15
BigGrin Nice progress AlanCool
#103 Posted : 26 April 2017 22:24:15
Great job Alan, very neat work as always.
#104 Posted : 26 April 2017 23:08:38
Thanks to all who looked in and for your comments, much appreciated...Cool Cool
jcomi
#105 Posted : 29 April 2017 00:16:12
Rank: Newbie
It's looking great!
Juan.
#106 Posted : 29 April 2017 00:30:38
jcomi wrote:
It's looking great!
Thank you Juan, much appreciated.... I hope when you start your own build you will show us some of your work, it would be great to see another build of this ship on the forum......Cool Cool
#107 Posted : 03 June 2017 23:49:19
Stage 10
This is a long stage where we complete the planking of the lower hull. Rather than try to cram everything into one complete post for this stage I've decided to break it down in phases, hopefully by doing it this way it will be easier for other builders to follow... Cool Cool
This update is short. To start planking the lower hull simply add two full rows ensuring you leave the 4mm gap at the bow. Trim the planks at the stern....Cool Cool .. The next phase will cover the transition under the stern gallery....Cool Cool
Foz
#108 Posted : 04 June 2017 06:32:20
Hiya ALan
Your build here, as with your others looks fantastic mate. Really looking forward to seeing more of it.
Foz Cool
#109 Posted : 04 June 2017 09:17:50
Looking really good.
It good that you can get so far down the bow section without having to start tapering planks.
Hope it all continues well.
#110 Posted : 04 June 2017 09:36:02
Thanks guys, appreciate you looking in and commenting....Cool Cool
@Tony, I agree with you regarding the bow. This build is following the printed instructions and up to this point no tapering is done, it starts with the next row. Even with the tapering, the planking at the bow does create a clinkering effect but this is taken care of when it comes to filling and sanding. The instructions in places take a very simple approach to planking whereas more experienced builders would have started tapering well before this point....
Hope this makes sense...
#111 Posted : 04 June 2017 14:52:29
Hi Alan.
Looking fantastic. look forward to seeing your progress Ian Cool BigGrin
#112 Posted : 04 June 2017 18:12:44
BigGrin Looking good with the meat going on the bonesCool
#113 Posted : 04 June 2017 18:29:55
Excellent builds Alan, look really good.Love
#114 Posted : 04 June 2017 22:39:33
Ian, Andy, Mark, thanks for looking in and the kind comments, appreciated....Cool Cool
#115 Posted : 09 June 2017 22:41:11
Next we continue with the next row of planks, this is the start of transitioning under the stern gallery and getting around the bow. Study the pictures in the instructions and the text to get a good idea of what you are trying to achieve. Working to transverse under the gallery is a little tricky and to make things easier I found soaking the planks to be of great benefit. You will also find it easier if you chamfer the edge of the planks to ensure a good fit to the preceding plank.
Add a complete row ensuring you taper the bow plank down to 2mm and leaving a 4mm gap at the keel. Taper the stern plank down to a point then repeat on the other side. Leave to dry fully before continuing.
Now add another two rows of planks in the same way, tapering the bow plank down to 2mm and the stern planks down to a point and again leave to dry fully after each row before proceeding.
Add another row of planks again tapering to 2mm at the bow, the stern plank does not need tapering.
Next phase we will be fitting the garboard planks and working down....
#116 Posted : 11 June 2017 21:30:10
Nice job on the planking, looking very neat.
#117 Posted : 12 June 2017 12:38:11
Hi Alan.
great job on the tapering of the planks at the stern. looks very neat and tidy.
Ian Cool BigGrin
#118 Posted : 13 June 2017 10:47:59
Very tidy work as always!
#119 Posted : 13 June 2017 14:38:10
Very neat planking there Alan. Top job!
#120 Posted : 14 June 2017 23:03:29
Nice work Alan. Looking great now coming along quickly.
Chris Cool
Guest (5)
24 Pages «<45678>»
This page was generated in 0.200 seconds.
