4 Pages 123>»
Birdseye View of the Trinidad Options
#1 Posted : 19 April 2017 09:39:40
Hi Folks!
After a bit of procrastination, i have today taken the plunge and subscribed to the Trinidad! Love.
I have ordered and built the larger of the 2 Hobbyzone model slipways (could have done with a build diary for that too LOL ), and now eagerly awaiting my first delivery. I would like to try to build her with minimum paint, so as to show the natural beauty of the wood, but i guess it depends on how well i get on (paint would cover a multitude of sins!). I will update this diary when i can.
I would like to thank everyone who helped contribute to this decision to build the Trinidad, and look forward to hearing your comments and, obviously, your help.
The Captn.
#2 Posted : 19 April 2017 10:55:25
Here is a photo of the jig. As others have said, it is massive! Bought from Hobbies
Limited of Norfolk. Very well built mind, just sparse instrutions. Should be able to accomodate this build.
Thanks for looking.
The Captn
#3 Posted : 19 April 2017 14:52:10
Well you certainly look set with all the right bits and pieces.
Hope you get a lot of enjoyment with this build.
#4 Posted : 19 April 2017 17:22:08
Thanks Tony, your not wrong there! I am sure it will be a pleasure looking at all of the build diaries BigGrin
The Captn
#5 Posted : 19 April 2017 19:19:24
BigGrin Nice choice on the Trinny and the stand/dry dock should do you well.
The trinny has some nice different coloured hardwoods in the kit aswell as for the X-section so with some carefull building you will get to show these off. The hull is double planked so dont worry too much how the first layer looks it just needs to be flat and well glued so the second planking sits just so. It may also be easyer to fit the dummy gunport blanks and the ladder block before the planking goes on it just makes them easyer to place.
You could consider using Danish oil for the decks and shellac for the hull or just use a good varnish Using either or all will give a great finish.
#6 Posted : 19 April 2017 19:49:05
Great choice with the Santisima Trinidad.
I have a work in progress of it myself, although it has come to halt a little while ago and now struggle to find time to continue. I'm probably going to have my father in law complete it for me as he has built the Victory and Sovereign of the Seas.
The Trinidad is a great looking ship and contains lots of really nice different types of hard wood to really enhance the finish Drool
I hope you enjoy building her Cool
#7 Posted : 19 April 2017 19:53:48
Hi Andy thanks for the encouragement. Funnily enough I though when reading the build why the dummy gunports are not fitted earlier, as you say it looks easier to do it before the hull planking.
Regarding paint vs plain, I'll just have to take my time and see how it comes out at the time BigGrin
The Captn
#8 Posted : 19 April 2017 19:56:51
Hi Dave
Thanks for viewing. Shame about not having the time to finish your model as it is coming on great guns ( all 140 of them lol). At least if your father in law can complete it she'll be going to a good home.
The Captn
#9 Posted : 19 April 2017 20:12:43
Glad you took the plung, will be following and happy to help further if you need anything
#10 Posted : 19 April 2017 20:50:31
Thanks mate, I'm sure I'll need it BigGrin I meant to ask....how come you only got the cross section?
Regards Gray
#11 Posted : 19 April 2017 21:23:47
Regards Gray
I purchased the cross section as a separate kit not through DeAg. its a great kit in it own right and a great addition to the full ship, sure you will enjoy building it. With Victory the cross section was at the end of the series not sure if it is the same for your trinny.
#12 Posted : 19 April 2017 23:02:29
Think you've chosen a first class build, this is one I have in my stash too and one day I'll get round to building her... Look forward to seeing how you progress so good luck with the build and enjoy the experience....Cool Cool
#13 Posted : 20 April 2017 09:11:01
Look forward to seeing your progress Cool
#14 Posted : 20 April 2017 15:26:13
BigGrin Hi You may find the link below useful as it gives the correct roll out of parts:-
http://forum.model-space...spx?g=posts&t=13387
#15 Posted : 20 April 2017 16:06:02
Thanks Andy, i had noticed that from looking thru the build diaries before i ordered.I just thought that as it had been raised a long time ago DA would have rectified it by now. Confused
Gray
#16 Posted : 20 April 2017 17:25:14
BigGrin The roll out will not change because its the inclusion of the x-section parts that has thrown things out.
If the x-section was supplied at the end of the build like the Victory one was then the sequence would be ok. It was highlighted as a guide for builders only just in case of any confusion.Cool
#17 Posted : 25 April 2017 20:39:00
Stage 1
Look what arrived today!!! Love
Well, made a start but I think I've made the caulking on the decking too dark (used a marker pen instead of pencil).
Have to see what it looks like when I sand it down.
Otherwise generally quite happy so far Cool
#18 Posted : 25 April 2017 20:59:49
Good start to your build.
It looks like you have opted to use the newer smaller build board? Its a nice addition to the larger one they make and will serve you well over the years with some of the smaller models you might go fir.
Hope you have some great enjoyment from building this one.
#19 Posted : 25 April 2017 21:00:17
BigGrin Looking forward to seeing your build Cool . I have used marker pens and they do tend to bleed into the wood so I only use pencil now Cool
#20 Posted : 25 April 2017 21:02:09
Blink The pen you have used has bled into the wood so no amount of sanding will straighten out the caulking lines. Best to have used a pencil to do this its a mistake I made also many moons ago apart from that the planks are tidy and well laidCool
4 Pages 123>»
This page was generated in 0.409 seconds.
