37 Pages «<1415161718>»
stevegbr
#301 Posted : 24 April 2017 10:44:15
tigerace wrote:
Great update SteveBigGrin looks to be quite a lump when built upBlink still itching to start mine but will hold on for a while till i`ve got more partsCrying Confused Bored BigGrin regards PhilCool
thanks phil. go on start it, LOL you know you want to. LOL LOL LOL
#302 Posted : 24 April 2017 12:37:51
Your a bad influence SteveBlink but i`ll wait for now Flapper or will iDrool LOL LOL PhilCool
stevegbr
#303 Posted : 24 April 2017 13:22:00
Just waiting for your build to start. LOL
Coser
#304 Posted : 25 April 2017 12:01:51
stevegbr wrote:
there was a bag of screws that was not present, that the one listed in the magazine so i used the bag with more screws. cant remember the letters at the moment. otherwise no problems spike. BigGrin
Think spike was referring to the fact that the magazine told you to screw the pipe on in the last stage, using 2 of the same screws you had just used to screw the previous part to the rest of the engine.
Obviously a misprint as you don't need to screw it at all looking at the pictures, and to use 2 to screw the pipe to the fixing but only 1 to screw the fixing to the engine is complete overkill.
Saw that one myself over the weekend and laughed at it.
Still don't like the large screw (compared to the size of the part) that you use to connect the fixing to the engine, so may modify one to be used without the head, then filler over the join and paint it before the engine goes in. I'll probably want to weather the engine anyway, so I should be able to hide this fact without much bother.
Current Builds
Hachette: T800 Endoskeleton
Finished Builds
#305 Posted : 10 May 2017 14:54:15
Looks quite a heavy lump when built up steve BigGrin i`m still holding on till i get the next set of issues then i`m going to start my buildBlink regards PhilCool
stevegbr
#306 Posted : 10 May 2017 14:58:04
it sure is phil, got parts 20 to 23 on the way, i think its carbs this time.
stevegbr
#307 Posted : 10 May 2017 15:01:11
this is what i found phil.
20 20A 1 Left the carburetor
20B 1 Right the carburetor
20C 1 Left the carburetor of under panel
20D 1 Right the carburetor of under panel
20E 3 Intake manifold
#308 Posted : 10 May 2017 15:02:25
ok steve BigGrin looking forward to starting mineDrool Drool its getting to the point of no space in my modeling room for all the bits Blink Blink regards PhilCool
#309 Posted : 10 May 2017 18:31:02
Oh, drat...
The more I see here, the more I'm tempted to start my build!
I'm really trying to save all of my parts until the end but all this has me drooling!!!
It really does look great.
Keep it coming.
stevegbr
#310 Posted : 11 May 2017 06:58:26
issue 20 is now showing what parts we are getting.
https://shop.eaglemoss.com/back-to-the-future-delorean/delorean-issue-20
stevegbr
#311 Posted : 12 May 2017 08:24:36
parts for issue 21, on the eaglemoss page.
https://shop.eaglemoss.com/back-to-the-future-delorean/delorean-issue-21
#312 Posted : 12 May 2017 11:14:46
Yep looks like the cylinder heads in that issue SteveBigGringreat stuff very coolThumpUp regards PhilCool
stevegbr
#313 Posted : 29 May 2017 14:50:55
here is issue 20.
stevegbr
#314 Posted : 29 May 2017 14:52:29
here are the parts for this issue.
stevegbr
#315 Posted : 29 May 2017 14:55:50
need to fix the three manifolds to the ports.
stevegbr
#316 Posted : 29 May 2017 14:58:27
next the covers.
stevegbr
#317 Posted : 29 May 2017 15:00:34
now to fix to top of the engine.
stevegbr
#318 Posted : 29 May 2017 15:02:24
here is issue 21.
stevegbr
#319 Posted : 29 May 2017 15:05:03
stevegbr
#320 Posted : 29 May 2017 15:06:30
here we put the cover on.
Guest (11)
This page was generated in 0.333 seconds.
