 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
Your a bad influence Steve  but i`ll wait for now  or will i  Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Your a bad influence Steve  but i`ll wait for now  or will i  Phil Just waiting for your build to start.
Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
stevegbr wrote:there was a bag of screws that was not present, that the one listed in the magazine so i used the bag with more screws. cant remember the letters at the moment. otherwise no problems spike. Think spike was referring to the fact that the magazine told you to screw the pipe on in the last stage, using 2 of the same screws you had just used to screw the previous part to the rest of the engine. Obviously a misprint as you don't need to screw it at all looking at the pictures, and to use 2 to screw the pipe to the fixing but only 1 to screw the fixing to the engine is complete overkill. Saw that one myself over the weekend and laughed at it. Still don't like the large screw (compared to the size of the part) that you use to connect the fixing to the engine, so may modify one to be used without the head, then filler over the join and paint it before the engine goes in. I'll probably want to weather the engine anyway, so I should be able to hide this fact without much bother. Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
Looks quite a heavy lump when built up steve  i`m still holding on till i get the next set of issues then i`m going to start my build  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
it sure is phil, got parts 20 to 23 on the way, i think its carbs this time.
this is what i found phil.
20 20A 1 Left the carburetor
20B 1 Right the carburetor
20C 1 Left the carburetor of under panel
20D 1 Right the carburetor of under panel
20E 3 Intake manifold
ok steve  looking forward to starting mine  its getting to the point of no space in my modeling room for all the bits  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,067 Points: 15,347 Location: ipswich
Oh, drat... The more I see here, the more I'm tempted to start my build!
I'm really trying to save all of my parts until the end but all this has me drooling!!! It really does look great.
Keep it coming.
Yep looks like the cylinder heads in that issue Steve  great stuff very cool  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
here is issue 20. stevegbr attached the following image(s):
here are the parts for this issue. stevegbr attached the following image(s):
need to fix the three manifolds to the ports. stevegbr attached the following image(s):
next the covers. stevegbr attached the following image(s):
now to fix to top of the engine. stevegbr attached the following image(s):
here is issue 21. stevegbr attached the following image(s):
here we put the cover on. stevegbr attached the following image(s):
