How do you glaze the bottom windows of Victory Options
Venice
#1 Posted : 16 March 2011 16:10:17
Just a thought going through Tomicks build diary, How do you glaze the bottom row of windows when it is already below a deck and now planked?
I only ask as I am on issue 34 and it helps to read ahead with the build and maybe I'm being thick or something but I cant see a way of being able to glaze the bottom row of windows unless its done from outside, That wont look to good.
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
Photobox build album
It cant be that bad, what do you mean it's sinking
benny
#2 Posted : 16 March 2011 16:46:08
just a guess but maybe a thin plastic sheet would go over the outside of the gallery and glued andthe detail will be applied over that..if you get my meaning
cheers benny
#3 Posted : 16 March 2011 16:50:36
Spot on benny
benny
#4 Posted : 16 March 2011 17:01:05
Tomick wrote:
Spot on benny
tomick now i know why you told me to hang fire on the gallery planking
cheers benny
Venice
#5 Posted : 16 March 2011 17:03:10
Ahhhh, at least I know then to put the curtains up before I glue the galley in place Glare
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
#6 Posted : 16 March 2011 17:09:47
Sounds like your planning to move in LOL
Venice
#7 Posted : 16 March 2011 17:13:29
Its bigger than my house so I might as well do Flapper
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
#8 Posted : 16 March 2011 17:13:34
venice what colour the curtains? and don't forget the nets first or the wife will skin yer alive.
benny
#9 Posted : 16 March 2011 17:13:37
theres alot of dolls house furniture on ebay including minature wallpaperBigGrin
cheers benny
Venice
#10 Posted : 16 March 2011 17:14:39
already bought the carpet and looking for a flat screen to mount on the wall Cool
Present Build:
H.M.S. Victory
H.M. Bark Endeavour
benny
#11 Posted : 16 March 2011 17:15:08
LOL
cheers benny
thomasmoult
#12 Posted : 16 March 2011 18:13:40
Hi Tomick,
Do you know how the build will progress in terms of the upper deck and therefore the middle gallery deck? I can't figure out what the cut-out is for in the middle of the middle deck frame.
Also, the small beam kind of peice that is fitted above the middle windows - is that for the next deck? And if so, will the next deck planking run the entire length of the ship (including the gallery?)
Cheers,
Tom
benny
#13 Posted : 16 March 2011 18:49:06
http://modelshipworld.co...r=asc&&start=50 check this build out and go through the pages wiull give u a bit of insight
cheers benny
#14 Posted : 16 March 2011 19:47:19
thomasmoult wrote:
Hi Tomick,
Cheers,
Tom
Our build differs from that of the normal AL kit, at this point the cut-out to the stern deck area appears to serve no purpose other than being a means for extraction of the companionway stairs should either be dropped into the middle deck area when being located, though later on something may well be planned for this area.
The beam that fits acros the inside of the gallery panel is a strengthening sbeam that also holds the slight curve of the panel.
KevinWalsh
#15 Posted : 20 April 2011 18:00:28
Rank: Amateur Level 1
A quick question regarding this topic, as I'm quite far behind (I've only just started assembling the internal keel and ribs) would it look odd if I glued the acetate sheet behind the gallery frames before I attach them to the main hull?
saintsman123
#16 Posted : 20 April 2011 18:37:31
Or pins, or the odd loose scrap of wood, or drill bit, or,or,or........
I'm glad its thereBigGrin
Come on you Jimmies
#17 Posted : 20 April 2011 19:54:50
It might, the gallery acetate/windows from the outside will be framed, and therefore if you locate the acetate from the inside you'll end up with a double thickness of window frame which will make the windows appear deep set if that makes sense.
#18 Posted : 23 April 2011 19:29:50
Not sure if this helps but Microsol do a pot of stuff called "MicroGlaze" and is very good at making windows (small mind you so don't try doing the house!!!)
