 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
here is part 60. stevegbr attached the following image(s):
here is the parts for this issue. stevegbr attached the following image(s):
need to put the rest of the parts on the inner pod wall. stevegbr attached the following image(s):
these are the parts for the next vehicle. stevegbr attached the following image(s):
got to put the wheels together. stevegbr attached the following image(s):
now to connect the wheels on to their axles. stevegbr attached the following image(s):
now the rubber tracks. stevegbr attached the following image(s):
here is part 61 stevegbr attached the following image(s):
the rib supports in place. stevegbr attached the following image(s):
the rest of the parts secured. stevegbr attached the following image(s):
here is part 62 stevegbr attached the following image(s):
here are the parts for this issue. stevegbr attached the following image(s):
put the rest of the parts on the inside wall of the pod. stevegbr attached the following image(s):
the parts for building the next vehicle. stevegbr attached the following image(s):
parts assembled. stevegbr attached the following image(s):
now for the tractor wheels for the front of the vehicle. stevegbr attached the following image(s):
now for the rear tractor wheels. stevegbr attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,062 Points: 15,332 Location: ipswich
OK - I now need to lodge an official complaint.
Your build diary continually pushes me even further into drooling over this one. I want the TB2 set. No question.
When it gets here in the UK, can I please have your bank details to subscribe, but have it delivered to me.
Seriously - for anyone who is a Gerry Anderson fan, this is a total no-brainer. Brilliant stuff. Keep it coming.
Roy.
roymattblack wrote:OK - I now need to lodge an official complaint.
Roy. thanks roy, glad you are enjoying it, it is a pleasure to build it, i have no regrets getting this from japan, its a shame its coming to a end.
