Dodgy Hull Ribs???? Options
jimbobuk05
#1 Posted : 16 March 2011 09:41:42
Hi Chaps.
I have just started on my build, now there is a good many
parts piling up. And I have a vague memory of reading the
forum awhile ago, and there was discussion of their being
someting wrong with one of the Ribs for the Hull.
I cant remember which one or what was wrong with it. And I
dont want to progress further without asking you fellas about
it.
So, was there a problem?
Or did I imagine it?
And if there was a problem, what was the fix?
Many thanks in advance.
Jim
#2 Posted : 16 March 2011 09:48:12
I think it was no.15 that was dodgy,the rib had moved while the laser was cutting it,need to check that the rib are symetrical with the other ribs and the decks steps line up with the rest.
#3 Posted : 16 March 2011 10:00:24
A couple of solutions here, but be mindful that not everyone had the problem
http://forum.model-space...aspx?g=posts&t=1310
http://forum.model-space....aspx?g=posts&t=1153
jimbobuk05
#4 Posted : 16 March 2011 10:45:41
Hi there,
Thanks for the help.
After looking at the different methods, I think I am
going to wait unil i have a deck in, and then use the
superglue method. That way, i have a solid structure
around the dodgy rib to work to.
Again, many thanks
Jim
Atholm
#5 Posted : 16 March 2011 13:52:30
Hi Jim
I found that the bottom of rib 15 was approx. 1,5mm higher than the bottom of the false keel. I increased the slot in the rib to lower the rib to line up the bottom of the rib with the bottom of the false keel.
jimbobuk05
#6 Posted : 17 March 2011 16:29:38
Thanks Atholm.
Think I have got it sorted now. Although I have
spent so much time looking at it that I would
swear bananas are straight now.Blink
Jim
jimbobuk05
#7 Posted : 17 March 2011 16:46:11
Thanks everyone for the advice. What I did in the
end was saw part way through the rib and with the
aid of a flexible ruler, lined up the rib, and used
a peg or two to hold the rib in place while the
superglue dried.
Seems to work okay. Time will tell.
Thanks again.
Jim
This page was generated in 0.101 seconds.
