Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
hi all i have finally got the gallery on that was a task probably bout 5 hours to get that right..i have 2nd planked the upper hull and attached the middle and bottom whales,i have a bit of trimming to do around the gunports and the end of the whales at the stern,that will be when its all dries i made that mistake on the other side  cheers benny
i know its a bit early but do we plank around the gallery windows cheers benny
this is what i mean as you can see the gallery is planked as in our case veneered..is this included in the build or can this be done now??  cheers benny
Leave well alone until you see what's happening with glazing and gallery mouldings
cheers tomick will do cheers benny
Hi benny! You've been busy looks OK! I must say don't worry about the gallery mouldings we only have issue 49 in the newsagents and still need 71 issues to complete the ship. On another point "THE UPPER GUN DECK PORTS" have you seen Tomick diary looks like some guns are set pointing down to get them to fit more centrally in the port. If Tomick's reading this Sorry Mate, but They Do! And when the dummy cannons are fitted in the centre of the ports you might just get away with it. So benny if your cannons sit to high try pointing the barrel down and see if you too can get away with it, this would save a lot of work.
Now how did I know you were itching to say so, if anything a tad on the high side but not angled down to make them fit, the barrels are set close to horizontal in relation to how the ship is sat and will be individually fined tuned before the deck goes in above. Preventing them from being knocked about whilst the rest of the build goes on is another matter
hi darron thanks ..yes i did notice the gun ports..i dont really want them pointed down,level would be ok,i might raise the ports by a couple of mill, i havnt put the upper wale on yet  ,it wouldnt take me long to do either..but i will wait until the next deck is done then offer up a cannon and see whats what cheers benny
a quick update the bow deck is planked and i have cut the wales around the ports..you notice i have cut away the gunport frames as i shaped the 2nd planking around the ports cause it didnt really work trying to get a recess,i found 12x12mm square metal tubing which a friend of mine is cutting into 2 mm strips which i will set back into the ports to form a recess i have tested a couple af them and they work a treat.  cheers benny
Hi Benny, Build looks very professional,you work to a high standard,will look forward to more pic's. tf64. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
hi all i had a problem with the cannons being to high in the ports they were touching the tops so i had to raise the ports by 2.5mm,and it worked great the wales hide any repair on the outside and the second planking did the same on the inside..i placed the cannons on the deck and as you can see the guns are now centre to the ports cheers benny
and heres some pics of my build so far..the bottom picture you can just see the test 12mmx12mm square metal tubing i am using for the recesses cheers benny
hope you all like my main mast  cheers benny
the deck has been oiled with a drop of stain i didnt like the different colours of planks  cheers benny
 cheers benny
Hi benny! Well you've managed to sort your port problem, I'm glad to see! and you wouldn't know it was ever a problem. I think other's will follow your work to correct the low ports as you have shown them the way. Nice Work!
thanks darron yeah it was quite easy after all that worrying cheers benny
hi all i have painted a section today to see what the metal 12x12mm recesses look like on the ports,and i am happy with the results,i will paint them properly and a bit of filler is needed when we are at that stage and the final paint job will be matt varnished to seal it  cheers benny
 cheers benny
 Rank: Pro  Groups: Registered
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
That 12x12 metal tube is a brilliant idea, on my way to B+Q as we speak lol Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
Guest (5)
