Wire Straightener Tool - by Artistic Wire Options
#1 Posted : 16 April 2017 15:18:43
One of the things that really niggles me are models that include wire as part of the component makeup but rather than supply nice straight wire the manufacturers insist on coiling it up which in many cases make it almost useless and good only for the waste bin.
There are several methods for straightening wire you will come across from clamping one end in a vice, grabbing the other end between the jaws of a pair of pliers and giving a sharp pull.
Other methods would suggest you can straighten wire by rolling it between 2 flat surfaces.
While looking through eBay recently I came across an item in the craft tools section called “Wire Straightener Tool “by Artistic Wire.
Always being one for a gadget I sent off for one to see what benefits it might give me.
What was interesting is that the item is stamped up “made in India” but mine came all the way from China – quite amazing to think how small the world has now become, and how international trade now is.
The tool is listed as being made of Nylon and I was not convinced that would be a strong enough plastic to work with wire. However, on receiving the item I thought at first the plastic parts might in fact be made of white glass as they are extremely hard and have that look and feel of white glass.
They are in fact plastic but a very, very hard type.
The tool is hinged and forms a triangle shape that you clamp the wire between before pulling it through and straightening it.
In the example pictures below I have taken a coil of Steel wire from a Model Expo kit and this is extremely hard and I cannot think this would be easy the straighten and remove the kinks from.
Having pulled the wire through the tool 3 times you can see that it does indeed straighten and remove kinks in the wire.
I am not sure to what gauge wire this would work to but brass wire could be annealed with heat to soften it if of significant gauge and I am sure would work just as well.
Cost of this little tool is around the £10.00 mark
From the couple of practices, I have had with it I think it will certainly have a place in my tool box from now on.
#2 Posted : 16 April 2017 19:25:32
Now that is a nifty little tool!
I've been doing some wire straightening myself as you'll see a little later down the Pups diary but fortunately my wire is micro-sized 0.2mm and also very soft. This gizmo would be great for the bigger wires though. And you're right - they always have to provide the stuff coiled up! (They should take a leaf from Albion Alloys!!)BigGrin
Robin
#3 Posted : 16 April 2017 20:14:41
Nice find, Thanks.BigGrin
I`ve got quite a bit of wire in both the Occre tram and dio kits, so purchased one.
For a few quid more than the tenner I got a metal anvil block as well.
Cool Cool Cool Cool Cool
#4 Posted : 16 April 2017 20:24:05
Quite an impressive tool, I cant quite get my head round how it works but obviously does. Definitely a useful thing to having lying around.
#5 Posted : 16 April 2017 21:17:03
Dave
Must admit when i saw this one i could not fathom how something that was not totally smooth would work but it does really well. Its also good having very hard plastic rollers which means the wire does not leave score marks in the surface.
#6 Posted : 26 April 2017 18:02:46
Hi all, BigGrin
Following on from Tony`s test of this tool, I tried mine on some 1.5mm brass wire.
This wire came fairly tightly coiled. (See pic 1), but after some firm pressure and about ten times through the tool the end result seems quite impressive. (See pic 2)
This tool I think was designed for use in jewelry making, (where finer wire is used), but performed well on some thicker modellers wire.
#7 Posted : 26 April 2017 18:18:57
Your postman has been kept busy Derek BigGrin
I think with some of the thicker coiled wires annealing over a flame softens brass.
Tried some 2mm recently and having given it a blast with the heat it went through the little machine well.
#8 Posted : 26 April 2017 18:39:47
Woah, that's quite impressive results Blink Blink definitely looks like a must have tool
This page was generated in 0.150 seconds.
