reinforcing plates on table base Options
greyhawk
#1 Posted : 15 April 2017 22:03:04
Hey guys, just got my full kit and ran into a little problem in build phase 2. Yes, really.
I suspect that the table base needs to be entirely level and stable. My problem is, that one of the reinforcing plates to be fitted in phase 2 has some very slight warp of about half to one millimeter. The lower edge is not straight but concave. I suspect it got dinged in transport.
Now as soon as I fit the plate the table is of course no longer stable, but wobbly. This is not remedied when screwing it to the table base.
Should I get it replaced or does this not matter in the end?
#2 Posted : 15 April 2017 22:10:00
The bed must be flat at all times otherwise you wont be able to set it up properly at the stage where your setting the print nozzle height. I would order a replacement part.
greyhawk
#3 Posted : 15 April 2017 22:54:57
This page was generated in 0.109 seconds.
