 Rank: Pro  Groups: Registered
Joined: 17/03/2010 Posts: 301 Points: 941 Location: fife
thats what i have just received the stern section and another rib current builds
 snap issue 6 with issue 7 parts left with WH Smith to sort out pick up both issues next week to see if theres been a mix up  at least i don't need to try & contact customer services
how strange,as my parts were correct,???? good luck for next week. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 if everyone was in the same boat (excuse pun)i would have accepted the issue & assumed parts for issue 6 would come with issue 7 but that was not the case as i saw Karls pics with correct parts
all the magazines in the local wh smith were the same issue six with issue 7 parts. strange current builds
Mine was ok mind you packaging could be better
Paul
Joined: 07/10/2010 Posts: 148 Points: 430 Location: At the back of my sinking boat
Hi Karl, I'm not 100% sure but the planking on the forcastle deck should cover the ribs. If you take another look at the what your parts should look like picture it shows the planking continues over the ribs also when placing mine back on after cutting our the rib spaces I noticed that the rib height was a lot lower than the deck. I have since re-planked the bits I cut out. Present Build: H.M.S. Victory H.M. Bark EndeavourPhotobox build albumIt cant be that bad, what do you mean it's sinking
thanks for that venice will check it out. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
 issue 7 has arrived,contents all ok.btw bought some gorilla glue to trial,did a little bit of planking with it,so far NOT impressed,takes ages to dry,not as quick as aliphatic glue. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Hi Karl, I've used the brown Gorila glue (expanding version), where you dampen the surface first; its great for where you need to span a joint gap because it expands/fills and is also waterproof, and when dry the excess which is foam like can be cut way, but its awful to remove if you get residue where you dont want it, the shelf life once open ain't too hot either.
Joined: 30/03/2010 Posts: 126 Points: 335 Location: Bradford West Yorks
I have gone through the newsagent called in last week and ordered all the parts up todate seven I believe had a cll from the newsagent to tell me i have six issues ready to pick up alot better than the subscription method I have got all the tools now so am not bothererd about the freebies looking forward to building it especially with quite a few of victory lads building it plenty of advice and encouragement happy modelling
Hi Karl are you enjoying the Endeavour build? I have 5 issues, waiting for more before I start, but not sure about the quality. Whats your view? Cheers MWG MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
hi, my opinion so far is,quality,fair,wood very prone to warps,have to keep a constant eye on it,and be ready to wieght it down after damping,I am doing a bit of kit bashing on this one,like walnut decking,and probily use different veneer to the one supplied. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Thanks for your input Karl, I will proberley stay with it,yours is looking great! MWG MWG BUILD DIARIES: HMS VICTORY, SOVEREIGN OF THE SEAS, SAN FRANCISCO II, HMS HOOD, HMS ENDEAVOUR LONGBOAT, HMS VICTORY X-SECTION, 007 DB5, NISSAN GTR, CUTTY SARK, RB7, AKAGI, BARK HMS ENDEAVOUR, HUMMER H1, MITSUBISHI ZERO.
Joined: 06/06/2010 Posts: 566 Points: 1,657 Location: UK
Hi Karl,
Can you tell me what the latest issue you have received is?
I have gone the subscription route and received issues 2-5 wityh no probs.
So far in March the have billed my card twice total amount about £45 (equates to about 7 1/2 issues???)& not received anything yet.
Thanks
Wilfy
issue 7 was the last one,no.8 tomorrow,this is why I cancelled my subs,I now collect from my local newsagent,did'nt like them taking my money first,and not delivering on time,yes I don't get the freebees this way but I don't get the stress either. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
Thanks Karl.
Evevtually spoke to someone there, apparently extra is for a special issue! Special issue after just 7 normal, could get expensive & to top it off these issues arrived late & have held despatch of all the normal issues up.
Think you have right idea of going to the Newsagent.
Build looking good by the way.
Thanks again.
Wilfy
 Issue8 another piece of deck,and 1 rib. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
