24 Pages «<23456>»
L'Hermione Build Options
#61 Posted : 29 March 2017 05:34:34
Looking good, very neat planking.
Cool Cool Cool
#62 Posted : 29 March 2017 09:03:02
Tomick wrote:
birdaj2 wrote:
]Are you planning to add the figure set to this one?
I have been trying to get hold of them but they are of stock just everyplace i have looked
That's because they have not yet been released by Artesania. We will have them in the online shop when available.
I will keep an eye open on the shop for them in that case. They look really nice from the pictures i have seen.
#63 Posted : 29 March 2017 09:16:37
Great job on the planking Alan. Top notch!
#64 Posted : 29 March 2017 11:57:49
Lovely work on the planking AlanBigGrin looking greatCool regards PhilCool
#65 Posted : 29 March 2017 18:59:58
Thanks guys for looking in and commenting, very much appreciated....Cool Cool .. If I can get the planking done the way I want then hopefully there will be little or no filler needed.... Blink Blink
#66 Posted : 29 March 2017 19:50:22
#67 Posted : 29 March 2017 20:03:28
stevie_o wrote:
Nice neat work Alan and a great guide to followBigGrin
Thanks Steve, appreciated as always....Cool Cool
#68 Posted : 05 April 2017 22:46:01
Stage 7
The planking done so far now has to be sanded smooth, filling any dents or hollows. Fortunately I haven't needed to use any filler as yet... The inside of the main deck bulwarks also require to be sanded smooth and for this task I found cutting the rounded end off of a nail file ensured I could get down to deck level without damaging the deck in the process..
The kit comes with a template showing the ribs and gun port positions. Cut the two templates out and then cut out the gun ports. Using masking tape I then attached the templates onto both sides of the hull lining up the rib markings and the bottom edge using the measurements contained in the instructions.
#69 Posted : 05 April 2017 23:03:11
BigGrin looking great Alan ,nice workCool
#70 Posted : 05 April 2017 23:11:05
Looks great Alan, very neat job.
#71 Posted : 05 April 2017 23:15:48
Nice update Alan, looks great mate.
Chris Cool Cool
#72 Posted : 06 April 2017 05:56:33
Looking good Alan
kpnuts
#73 Posted : 06 April 2017 06:34:27
That is some of the neatest planking I've ever seen.
#74 Posted : 06 April 2017 07:53:05
Lovely neat work on the planking.
#75 Posted : 06 April 2017 09:09:57
Brilliant job on the planking!
#76 Posted : 06 April 2017 10:40:30
Thanks everyone for looking in and the very nice comments, always very much appreciated. Am now in the process of marking and cutting out of gun ports, will update as soon as its done....Cool Cool
#77 Posted : 06 April 2017 13:43:58
Hi Alan.
Very neat and tidy build. Looking fantastic.
Ian Cool BigGrin Drool
#78 Posted : 06 April 2017 18:03:39
BigGrin Superb planking Alan , loving this build Love
#79 Posted : 06 April 2017 18:44:23
Ian, Martyn, thanks for the great comments, appreciated....Cool Cool
#80 Posted : 14 April 2017 23:46:16
Moved this build on a little further. Once the templates were positioned correctly the next job was to mark out all the gun ports and then remove the templates. Happy with the marking I then moved onto actually cutting out the ports, this I did by using a 1.5mm drill, drilling holes around the inside of the port edges ensuring I left a margin of error.
Using a fresh blade I then cut the ports, cutting slowly so as not to splinter any of the wood especially on the inside of the ports on the main deck.. The last job on this build session was to tidy up the port edges using fine files and emery boards. The final clean up will happen when I come to fit the port linings....Cool Cool
This completes stage 7.
24 Pages «<23456>»
