Joined: 23/02/2017 Posts: 120 Points: 366 Location: Sweden
Hi. I decided to start a builders diary here at Model Space. I got my big package end of January.  Since I live in Sweden Subscription is not an option for me. So I got all issues at once. Box was 55x55x50 cm, and the weight was 12kg. So around 20x20x20 inches and 26 lbs.  The magazines were placed at the bottom of the box, and on top were all the plastic bags with parts.  I thought long about opening them up and sort all the parts. I were afraid to mix them up. But many pieces are marked with ID's and the magazines are great reference to identify pieces in case I do mix them up. I opened all plastic bags and sorted the pieces. I left a few small bags with tiny pieces in their bags. I first put everything on shelves sorted as Interiour, metal, sprues, big hull pieces, small detailes and all screws and tiny pieces went into plastic boxes with compartments. Everything is now better stored in see-through boxes.
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 25/05/2015 Posts: 66 Points: 204 Location: Minneapolis
Holy smokes! So that's what it looks like all packed into one box; I always wondered.
Have fun with it! It'll consume you for a long, long time.
I gave the ship or build the name "Crescent Moon" because there might be a one on the ship. And I wanted to call it something.
It will not be a Millennium Falcon. I knew that from the start. I want to do something different.
I will also make a display cabinet for the model. A table with a glass top. The inside walls of the cabinet will be a diorama, a square or landing pad with buildings surrounding it.
That's the idea or dream anyway.
Nice start, I bet that took ages sorting all those issues out. I look forward to seeing it progress. Mark Regards Markwarren (Mark) Admin
Joined: 13/05/2016 Posts: 130 Points: 386 Location: Murrieta, CA (USA)
Hi Lundin, welcome to the build forum. Can't say I am the best a building a model as this is the first model I have been building in over 40 years. Best of luck with your build lots of good info can be found in other build diaries. Make things as simple as possible but not simpler... - Albert Einstein
Hi Lundin, Welcome to the forum and I look forward to see what comes of all those parts. They look awesome. Congrats on your "Blue" medal for starting your diary. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
The biggest difference when getting all issues in one go is that I'm not forced to build according to the magazines. But that is also the danger. I might miss an important step if I don't check the mags before I start. In the beginning started off by assembling some smaller parts to get a feeling for the plastic parts, glue and paints.    The landingstruts or legs were a good start. They have an awesome design I think. I will probably have parts of them in shiny chrome to suggest some sort of hydralics. I also wanted to have a piece of hullplating to test colors on so I built one from styrén. I added lots of greeblies I made myself and pieces from old sprues.      Since I were not sure what the best approach were I tried a lot, but it turned out better than I had hoped for. I'm going for a green Falcon btw. (I think)
Joined: 23/01/2017 Posts: 62 Points: 186 Location: Livingston
This will be an interesting project! Can't wait to see your progress
Why doesn't my images show up? It worked fine yesterday.
I solved it.
I wanted to do something about the battledamages on the hull, that looks more like chickenpox scars. I drilled holes, used a warm soldering iron to distort the holes, and some putty. Turned out pretty good. Looks better with some primer on. But I need to revisit it to smooth the putty better to the hull.
Looks like a fantastic model in the making. Will follow your updates with great interest Happy Modelling
First I thought I would spend most of my time and efforts on the exteriour and the surrounding diorama but the interiour was too tempting and fun. So the far too smooth floor and walls.  I added pieces of styrén to the walls. For the floor I opened up one of the maintenance holes and glued thin strips to divide the floor into pieces. I have seen other builders buy detailing kits for the floors in metal, but I found it too expensive. So I used plastic insect-netting. I cut out pieces that fit and glued them in. The netting "density" is 6 squares per centimeter. The scale is a bit too big. You couldn't really walk over the floor without getting stuck, but it turned out very good. And didn't cost much. I just wanted something that could catch the weathering in a good way. Primer and some preshading.  I am not very used to the painting process, so I am trying different methods. I finally got my airbrush to work properly. I didn't use enough thinner before so it clogged pretty fast.  Some base colour. As I have mentioned, I will not build the Millennium Falcon, so I will not use the sofa, chessboard and bunkbed. But they will be used in the diorama in some way. I have some cool ideas. It's a bit sad. I thought about it for a long time. But "kill your darlings" as they say. I need to make this into my ship. This is how I planned the hold. Some cells to keep people or animals locked up. That the ship is owned by bounty hunter or smuggler of rare animals. Something like that.    The cages. I also used the netting for the cages. It is see-through and turned out very nice. The doors are high enough for a grown man to walk through. A scaled down man.    The finished main hold.    I also made an maintenance pit. Lots of small pieces from old sprues.
 Some nice work there Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 30/04/2015 Posts: 263 Points: 795 Location: Los Angeles
What you're doing looks really cool. Definitely making it your own ship.
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
Awesome to see someone else do a not Falcon YT-1300 build DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
Joined: 08/05/2015 Posts: 239 Points: 693 Location: Wisconsin
Very interesting build. Will be following to see what you come up with.
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
It will be nice to see a different take on this model. Looks great so far. Will be watching this build with interest. Stephen Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Wow, you've certainly got you tech well and truly stuck into this project. Looks amazing, great to see something completely different. The hold area looks superb. Mark Regards Markwarren (Mark) Admin
I like the approach you are taking and think it will look really nice in the green colour scheme
Guest (11)
