maurizio67 attached the following image(s):
Very nice details
Following the step of this awesome build i just bought the dcals set tyres for mine mp4 from autograph. I would ask to Maurizio (also to Malc and the other mates tha made this job) how is the right metod to apply the decals tyres. I must wash or spray the rubber tyres with something? Thanks in advance Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
frah2o wrote:t
nooooooooooooooooooooooo
Those rivets look seriously small. Fiddly to work with I bet, but a nice choice. Well done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely details being added, great work Maurizio Al
put the carbon is becoming a very long process....
Hi Maurizio, i ask you some details about your (awesome) build I read whole topic to find spec for extra coolant hoses. When i can get violet hose and braided hose with the plug end? (in the red and green circles) frah2o attached the following image(s): Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
frah2o wrote:Hi Maurizio, i ask you some details about your (awesome) build
So larger radiator: Tapping 0.8 and then switch to a tip 2 mm, fitting insertion aluminum DMADM3094 Combination fitting 4 1.88mm taken from model fitting and baracca.Il 'hex the round hole and then to fill the space that had been created I used the liquid vinyl positioned with the toothpick in order to make uniform and devoid of spaces drilling, once I dried the vinyl I painted with aluminum above the vinyl "always with the toothpick" then I cut about 1.5 mm tube silicone and positioned above the painted vinyl so as to simulate a gasket. For the small radiator I drilled with a 0.8 mm bit 'attention to the chrome if escapes the tip goodbye ... "and then enter the chrome siding, but now I have seen that there are more but these are of hiroboy; 1:12 Hose Joint Set B - P1119 for the braid tube or modeling cabin or always hiroboy
Great detail with the rivets, Nice work Mark Regards Markwarren (Mark) Admin
quite firm, they are not coming to me more packages !!!
Now can start work again!
Very neat
Such realistic detailing, you are really making a wonderful model. Happy Modelling
Nice work on those brake reservoirs, they look suitably dirty.
Joined: 01/12/2014 Posts: 102 Points: 312 Location: Chicago, IL
Awesome detail work. I can't wait to see more from you.
Photography does not show the details in the best nest
Guest (10)
