RM1 wrote:The battery has one of it's connections standing vertically with no cable so I've added a cable and connector more or less as it appears in photos of the real thing. pink tube radiators that type of block you used to stop the tube to cockpit? Thanksπ
maurizio67 wrote:RM1 wrote:The battery has one of it's connections standing vertically with no cable so I've added a cable and connector more or less as it appears in photos of the real thing. pink tube radiators that type of block you used to stop the tube to cockpit? Thanksπ Hi Maurizio,
I'm not really sure of your question but I think you are referring to the straps that hold the "pink" tubes to the monocoque chassis? As in the picture below.
They are top studio parts "wire band set".
Hope that helps.
Malc RM1 attached the following image(s):
Yes yes.... Thank's!!!! ππ»ππ»ππ»ππ»ππ»
Finished !!!
Now with so much detail to display I really can't cover it up with the body.RM1 attached the following image(s):
I'm going to be a bit unconventional here with the body shell.
I've made a support bracket from sheet Aluminium. A "Z" bend epoxied onto the base plate. RM1 attached the following image(s):
It'll support the body like this. There's a plastic clamp to hold it in place.RM1 attached the following image(s):
Covered with Carbon effect Sticker.RM1 attached the following image(s):
In place in the collection. RM1 attached the following image(s):
Very well done. An unusual way to display the body but it looks fantastic and saves a lot of space while allowing you to see the whole of the surface detail. Very well thought out. Happy Modelling
That looks great Malc  good idea and well thought out. Al
wow !!! very very nice support
Many thanks for all the kind comments. I've really enjoyed this build and am very pleased with the final result. Malc.
Very nice result, WTG Any idea what`s next in line ? Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
delboy271155 wrote:Very nice result, WTG Any idea what`s next in line ? Regards delboy271155 (Derek) Thanks Derek. As for the next one..... could it be a Mclaren?
Hi Malc. My 11 pack is coming. I will work on turbos and exhaust. I'll repaint the turbos and exhaust. - The turbos stickers is with the pack or is an extra decal? - I searched the carbon decal for intercooler duct but i didn't found (are no longer avaible from autograph). If i right remeber, the decals are in 4 parts for each duct. Do you use autograph decal or you self made it? I need the mask to reproduce the 4 carbon parts, but i don't know how I can. Thanks for patience Malc Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
frah2o wrote:Hi Malc.
Hi Francesco, The nameplate stickers for the turbos are supplied in stage 69. That's a pity about the intercooler decals. I used those on my build. I have included a photo of my decals which maybe you can use as a rough guide by printing and enlarging the image? Otherwise you can make a template with tracing paper. There are 4 decals on each intercooler. I hope that helps. Malc. File Attachment(s): RM1 attached the following image(s):
Thanks to much Malc. This pic is perfect and your help is great. I'll stamp it and i'll resize to match with size of ducts. Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
