3 Pages <123
Top Deck Problem Options
riff-raff
#41 Posted : 07 March 2011 16:11:57
At least it keeps the build intersting - If I'd have wanted things that easy I would have bought a plastic kit.
Built:
z8000783
#42 Posted : 07 March 2011 16:28:39
Groups: Unapproved
mmmmmmmm....
John
riff-raff
#43 Posted : 07 March 2011 17:11:46
saintsman123 wrote:
I've solved the problem (for me anyway), as I'm not ever going to get historical accuracy, I've taken the barrel from a couple of the cannons, and filed down the groove where the barrel pivots, this has lowered the barrel enough to get them through, I have also filed the wheels to make them a bit thinner which allows me to centralise the guns in the port if I run them out.
This seems to be the best method of solving this one.
I have put the deck supports back in place to raise the deck back to its proper height. I have over sanded the deck where it meets the deck supports by 0.5mm I have then copied saintsman123's idea of lower the pivit point of the barrel. I have done this by approx 1mm on all cannons. I have made a wooden section to replace the brass pieces that doesn't look to bad
This has lowered the cannon barrels by 1.5mm in the gun ports and hey-presto it works a treat and I only have 0.5mm to make up which shouldn't be to difficult.
Built:
riff-raff
#44 Posted : 07 March 2011 17:12:54
z8000783 wrote:
mmmmmmmm....
John
Not exactly what I meant but my fingers sometimes go faster than my brain. but you know what I mean.
Built:
z8000783
#45 Posted : 07 March 2011 17:19:08
Groups: Unapproved
riff-raff wrote:
z8000783 wrote:
mmmmmmmm....
John
mmmmmmmm....
John
z8000783
#46 Posted : 07 March 2011 17:32:56
Groups: Unapproved
I guess these are the ports we are talking about here.
John
riff-raff
#47 Posted : 07 March 2011 17:42:59
Yes John.
Built:
z8000783
#48 Posted : 07 March 2011 17:52:37
Groups: Unapproved
Bearing in mind some of the measurements we've been taking are to an accuracy of 0.5mm or just over 4cms scaled up, it's a bit odd that this is so far out according to Tomicks build isn't it?
John
saintsman123
#49 Posted : 07 March 2011 19:37:03
I've been looking at the build on model shipworld
http://modelshipworld.co...r=asc&&start=50
Scroll down till you see the pic of the guns agains the ports
I know that the model we are building is basedon the A/L kit, and that as it is a partwork not everything is exactly the same as the original kit, but I can see from this persons build that the cannons are slightly different, they look ever so slightly smaller to me as they seem to fit well inside the cutout portion of the gun port, and looking at the front of the carriage it almost fits inside the linings. Does this mean (as I mentioned in an earlier post)that our cannons are maybe slightly larger than those that the hull dimesions require? As I say I understand that our model is not the exact A/L kit,especially as it looks as though this builder has no gun rigging (and that the A/L kit comes with more "real" cannons, but if you look at other pictures of his build, the barrels seem a bit smaller, I know it's difficult to tell exactly from a photo, but this is just my opinion.
Come on you Jimmies
darrend
#50 Posted : 07 March 2011 19:41:27
well all i can say is that i am that far behind you all that hopfully someone will have come up with a fix before i get to this point.
what happens if tomicks build looks wrong does the build come to a grinding halt?
z8000783
#51 Posted : 07 March 2011 19:45:31
Groups: Unapproved
I think we are still waiting for Tomick to comment on his build and to say if he has tried one of the cannons against the port.
John
#52 Posted : 07 March 2011 20:46:57
You'll see the result when the diary build for issue 50 is posted later this week, and before you ask no adjustment or 'made to fit' gone on.
z8000783
#53 Posted : 07 March 2011 20:50:41
Groups: Unapproved
Thanks, will (try to) be patient.
John
darrend
#54 Posted : 07 March 2011 21:09:41
cheers tomick - im not doubting you just interested to see how you get on as i am following the offical build also.
saintsman123
#55 Posted : 07 March 2011 21:20:04
Thanks Tomick, I normally build in my living room, and the boat sits there all day looking at me, as of 10 mins ago I've moved it away from sight to stop me meddling
Come on you Jimmies
riff-raff
#56 Posted : 07 March 2011 21:39:24
Your lucky mate - my wife has designated me 3' x 2' area of kitchen worktopGlare
Built:
saintsman123
#57 Posted : 07 March 2011 22:03:17
Couldn't help my self, had to meddle, and have now found out why my ports are too low
In Issue 29 page 10/11, the top of the gunports is on a 1/2 plank, with all the other detail in the drawing it was difficult to count all the planks, so when the ports were marked out, I marked them all along making sure I was on the 1/2 plank at the top, this meant by the centre area I was at 2&1/2 from the top, which is 1/2 a plank too low, hence all the guns hit the top.
The instuctions in the mag say "when marking the positions of the ports, refer to this plan"
So thats what I did
However when you turn the page, and look at the various steps, step 8 is a good close up, it shows the port marked on the join of a plank which is 2 planks down (although if you look at step 5 the far right upper port looks lower than the rest)
So the plan say's one thing and the pics show another, so thats the reason my ports are too low.
Looking at MrT's build, he's gone as per the pictures, so his ports are going to be ok. If you have followed the plan you may have a problem, if you have followed the photo's you should be OK
Come on you Jimmies
benny
#58 Posted : 14 March 2011 21:33:09
hi all i have just finished planking the middle deck,gave it a good rub and offered up a cannon and the ports are 2.5mm to low,so i have no choice but to raise them,now i know i have to raise all of the ports on that deck..does any one know if this will cause a problem later
cheers benny
benny
#59 Posted : 14 March 2011 21:53:32
the pictures in that build show his cannons are pointing down too along the middle gun deck
cheers benny
benny
#60 Posted : 15 March 2011 16:16:39
obviously not i have moved them anyway
cheers benny
3 Pages <123
This page was generated in 0.166 seconds.
