 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
tigerace wrote:Hi Steve great update  looks impressive  question have you had problems fitting the screws ?seems a lot of builders have had problems with screws  regards Phil you must use the right screwdriver phil, the one i use it gets to the bottom of the pozi.
got to insert the rim in to the tyre. stevegbr attached the following image(s):
now for the wheel cover which is held by three screws. stevegbr attached the following image(s):
now you use a screw and the plastic washer, and secure the wheel to the hub, be careful not to over tighten the screw, lastly insert the wheel cap. stevegbr attached the following image(s):
here are the parts for issue 14 stevegbr attached the following image(s):
this two parts are secured by two screws. stevegbr attached the following image(s):
this parts are secured by one screw. stevegbr attached the following image(s):
fit the bracket to the chassis, there is a locating pin for one hole then secured by one screw. stevegbr attached the following image(s):
secure the hub strut to the chassis, held by one screw. stevegbr attached the following image(s):
one screw connects the top rod withe hub. stevegbr attached the following image(s):
connect the caliper with the disc with one screw. stevegbr attached the following image(s):
rear strut and one screw to connect the lower hub together. stevegbr attached the following image(s):
spring coil put on strut and secured it to top bracket by one screw. stevegbr attached the following image(s):
front driveshaft parts. stevegbr attached the following image(s):
secured by one screw, and kept for future fitting. stevegbr attached the following image(s):
Steve That is all looking really good. Happy Modelling
thanks tony, its a big car now.
here are the parts for issue 15. stevegbr attached the following image(s):
now we put the tyre on the rim. stevegbr attached the following image(s):
now to put the wheel cover on, held by three screws. stevegbr attached the following image(s):
Guest (8)
