Wire Cutter, guillotine Options
#1 Posted : 18 March 2017 19:44:17
I have been giving this tool a bit of a bash recently, its an excellent tool if you have a lot of repetitive brass or plastic rod to cut at the same length. The tool cuts from 0.0mm to 1.50mm and the guillotine cuts striaght with no pinching so no needful filing off ends to square them up. There is a length stop to allow repeat cuts of the same length, its relatively cheap too but very good quality.
http://www.proopsbrother...0-15mm-j1002-1428-p.asp
This page was generated in 0.075 seconds.
