6 Pages <12345>»
Occre Lisboa Tram Dio Options
#41 Posted : 13 March 2017 00:15:19
Looks great Derek, very nice touches being done....Cool Cool
#42 Posted : 13 March 2017 00:32:12
Thanks Alan, BigGrin
There is one minor issue with the dio. The material thickness for the cobbles means you have to prop up the drain grate slightly to keep it level with the road surface, but no great problem.
The benefit though, is that it now has some depth under the grate to give it some added realism.
#43 Posted : 13 March 2017 14:55:51
Lovely work Derek BigGrin like the grate and those kerb stones they look greatBigGrin regards PhilCool
#44 Posted : 14 March 2017 19:23:26
Hi looking great enjoying following this one. Cheers mick. BigGrin
#45 Posted : 14 March 2017 20:38:44
Lovely work Derek, lookng very nice so far Cool
#46 Posted : 28 March 2017 14:58:29
Hi Derek.
looking fantastic, very well done.
Ian Cool BigGrin
#47 Posted : 13 April 2017 19:45:37
Hi All,BigGrin
Just a small update as what was going to be a workroom refurb has turned into a rebuild to accomodate large builds and new work areas.
Anyway more on that later, but for now I`ve finished the pavements and about to seal the whole base before I paint and weather it.
I`ve not laid the paving stones 100% regular and made very slight differences in their thicknesses to make it look like a well worn pavement.
More coming soon.Blink
#48 Posted : 13 April 2017 19:56:54
Derek
Fantastic.
Really been enjoying seeing this one cone together being somewhat of an Occre "fan" BigGrin not always the easiest of models to put together but you are doing a sterling job.
As much as occre have some "interrsting obsatcles" in their builds these diorama kits are a bit special.
Nice to see your latrst update
#49 Posted : 13 April 2017 22:52:55
Now that does look good Derek, great work....Cool Cool
#50 Posted : 14 April 2017 08:13:52
BigGrin Looking good Derek, hope your going to dirty it up a bit looks like the street fairy's are keeping it looking brand new at the momentCool
#51 Posted : 14 April 2017 13:09:25
First all those cobbles and now paving stones, your a glutton for punishment Derek LOL looking good though Cool
#52 Posted : 14 April 2017 15:04:01
Thanks for the kind commentsCool Cooland to those that took the time to look in.Cool Cool
Andy: Watch this space to see what the "Grubby Gremlins" do to the street.
A clipped pic is attached below to show what I will be aiming for.
The street weathering takes a full build stage of the 21 stages that
complete the dio. So far only two stages have been completed so a
long way to go yet.Blink
Al: Cobbles and Paving done.BigGrin
Lots of building to do.
Then it`s on to the weathered roof tiles.Blink Blink
I think that the most repetative bits are now done though.Cool
#53 Posted : 14 April 2017 16:39:49
A kit with so much build time is good value for money.
Sure you will make a great job of the weathering.
#54 Posted : 14 April 2017 16:42:47
Really like those cobblesBigGrin Drool Drool outstanding so far Derek BigGrin regards PhilCool
#55 Posted : 14 April 2017 20:48:47
Certainly is good value as CMB are selling both tram and dio for a few pence under £130 all in.
( Derek )
#56 Posted : 19 April 2017 07:12:04
Hi All,BigGrin
Been looking at the weathering and effects possible for this dio and what`s on the market.
I was thinking about what sort of street litter would be around, apart from wear and tear of roads and pavements.
Leaf litter came to mind and whilst searching around ebay for such items, came across this.(Make your own version).
Available in differing scales and leaf types, these cutters are said to work on paper and the like plus real dried leaves.
Here`s the link to one type, check out the other ones on offer by the same seller, on show at the bottom of the page:
Leaf cutters
#57 Posted : 19 April 2017 08:33:32
I have seen these on some of the modelling web sites and they look a very good idea.
Thet do them in several leaf types i think.
The only minor issue i can see is that if you are working in a small scale the larger of the leaf shapes would not be required and you could spend a time having to sort through the pressed out pieces.
But working in a larger scales i guess you could useall of the pressed out pieces.
Its an interesting one because what sort of litter would they have had years back? And did they have as much as we see these days.
While probable not the right era for your build there are some interesting pictures here.
https://www.google.co.uk...ri#imgrc=XnxQQv8wW0yrQM:
#58 Posted : 19 April 2017 14:58:38
Hi Derek i have used products from this range in the pastBigGrin regards PhilCool
http://www.scalemodelshop.co.uk/grass.html
#59 Posted : 19 April 2017 16:48:27
[quote=tigerace]Hi Derek i have used products from this range in the pastBigGrin regards PhilCool
http://www.scalemodelshop.co.uk/grass.html[/quote]
Thanks for the link, there`s some useful items there.
#60 Posted : 19 April 2017 16:53:38
[quote=birdaj2]I have seen these on some of the modelling web sites and they look a very good idea.
https://www.google.co.uk...i#imgrc=XnxQQv8wW0yrQM:[/quote]
Thanks for the link Tony.Cool
It`s still some way off before I get to this part of the build so time to investigate the possibilities.
6 Pages <12345>»
This page was generated in 0.338 seconds.
