 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
roymattblack wrote:The Mole looks really nice - except for the seam line right through the 'drive belts' along the sides. Could they be sanded off, or even replace the belts with correct size cable tie strips?
I really want TB2 if it hits the UK.
It should be here later this year roy. As for the seams. It Dont look that bad to me. We all look for different things.
I hope its released later in the year then my subscription to the U96 will be done  fingers crossed regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
Ditto the above. Hopefully after the Shelby is finished.
Looks really good and the mole was a favourite mini vehicle for me. Hope it all continues to go well. Happy Modelling
I always preferred the Firefly. Now, a nice BIG kit of that one...? Roy.
here is part 52. stevegbr attached the following image(s):
need to glue the two halves together. stevegbr attached the following image(s):
here it is with all the parts attached. stevegbr attached the following image(s):
is it exacly the same as the first pod? the outer walls
ElekTr1C wrote:is it exacly the same as the first pod? the outer walls i think so, only got parts up to issue 57.
got to attach the front wall to the pod. stevegbr attached the following image(s):
here we have part 53. stevegbr attached the following image(s):
here are the parts for this build. stevegbr attached the following image(s):
put the two halves of the rear wall together. stevegbr attached the following image(s):
now to put the rear wall on the pod. stevegbr attached the following image(s):
fitted. stevegbr attached the following image(s):
now to fit the four parts on the front of the pod. stevegbr attached the following image(s):
Coming along nicely Steve Al
Spal wrote:Coming along nicely Steve Al it is al, the end is coming fast.
