Radiator hose ( clear tube with paint "sucked" into it ) put on both sides. I made Undertray support rods from steel shim and and fastened to the cylinder heads with PE bolts. Also added extra sensors with cables to the exhaust manifold and wastegate. The sort of things I could see in various photos and what others doing this build have added. Oh.. and of course have started to place the chassis decals. RM1 attached the following image(s):
Same on the right hand side.
Looking fabulous Malc Al
Thanks for the nice comments guys.
Stunning attention to detail, a joy to watch this come together
malc, the tool you used to drill holes in the mesh is self built or is in the shops?
maurizio67 wrote:malc, the tool you used to drill holes in the mesh is self built or is in the shops? Hi Maurizio67. I've sent you a PM. Malc.
Looks amazing, lots of detail and superb skills on show.
Bodywork and tyre detailing complete. Nearly there !!RM1 attached the following image(s):
She's looking great Malc  those new tyre valves look good. AL
First class build, she's looking fab..... Regards Alan
Thanks Guys
Well.. here we are with the complete chassis + wheels.
I must display this model with bodywork off . It would be a crime to cover up all this detail in a fab kit like this.RM1 attached the following image(s):
A little detail on the brake discs with the addition of cut wire bonded on as well as temperature indicator decals.RM1 attached the following image(s):
Cockpit details RM1 attached the following image(s):
She's a stunner Malc  great work. Al
Spal wrote:She's a stunner Malc  great work. Al Thanks Al.
