Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Hi all, This will be my first build of this size, and I'm going to try and keep a build diary through out the whole build. I have done small scale models before but nothing like this. Ritchie69 attached the following image(s): Completed - R2D2
So here goes with the start of my build. Because I'm a novice at this I am not going to weather my R2. Ritchie69 attached the following image(s): Completed - R2D2
Next 4 issues Ritchie69 attached the following image(s): Completed - R2D2
Hi, Welcome to the forum and the R2 build. Well, you are certainly off to a flyer and it looks good, well done. Good luck with your build and should you have any questions, just ask. Also congrats on your "Blue" medal for starting your diary. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Welcome to the forum, the R2 kit is really nice.
Welcome Ritchie and thanks for sharing your build. It looks like you're off to a great start, hope you enjoy it
 Welcome to the forum Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum. A great start to your build.
Welcome to the forum Richie, looks like you're off to a great start..... Regards Alan
Welcome Richie. Your off to a great start on r2. Look forward to your build. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Welcome to the forum Richie,I look forward to seeing your progress. You've certainly got off to a good start. Mark Regards Markwarren (Mark) Admin
Thanks for the welcome all. So far i'm happy with how it's going, and the quality of the parts are good too. Completed - R2D2
Welcome Ritchie,looks like a good start to your build.
 Rank: Semi-Pro Level 1  Groups: Registered
Joined: 23/01/2017 Posts: 62 Points: 186 Location: Livingston
Hi, great start to your project!
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
Welcome and good luck, Great start so far to what is going to be a fantastic build.
Today I received a new issue 4, as the first one the print was poor. To my surprise they sent me all the parts as well. Thanks all for the warm welcome. Completed - R2D2
The next 4 issues have arrived (9, 10, 11 & 12) and I got straight down to building. Issue 9 The last piece of the top of the dome fitted & the metal ring attached, this has secured it all and is very secure. Ritchie69 attached the following image(s): Completed - R2D2
Issue 10 Next layer of the dome started & lens mount done. Ritchie69 attached the following image(s): Completed - R2D2
Issue 11 Not much to do here, just attach a part of the second layer of the dome. Ritchie69 attached the following image(s): Completed - R2D2
Issue 12 2 more dome parts to attach and the leg frame to build. Ritchie69 attached the following image(s): Completed - R2D2
