106 Pages «<1314151617>»
#281 Posted : 22 February 2017 21:54:19
A close up looking forward.
#282 Posted : 22 February 2017 22:01:57
Well that concludes this part of my build. Doing the modifications and repair work took far longer than I originally envisaged; a total of 2.5 weeks!
I'm so glad with the end results. After all the mistakes, rectifying work followed by more mistakes, rectifying, modifications and finally fitting, I can now look at it without being met by an eyesore.
A lot of work to produce an accurate androbust modification but I can now move on to the other parts of the hull very happy.
Thanks for looking in, have a great weekend and happy modelling.
Kind Regards,
#283 Posted : 22 February 2017 23:59:26
Can only agree with you Phil, she is looking really good.....Cool Cool .. Very nice work....Cool Cool
#284 Posted : 23 February 2017 15:57:59
Thank you Alan!BigGrin
#285 Posted : 23 February 2017 16:07:55
Hi Phil.
some very nice modifications. very well done.
Ian Cool BigGrin
#286 Posted : 23 February 2017 20:47:56
That was quite some work you had to do there Phil, but the end result was well worth all that effort. Great job Cool
#287 Posted : 27 February 2017 11:40:56
Thank you for all the kind and encouraging comments. More posts from 'The Dockyard' to follow mid-week.
Kind Regards,
#288 Posted : 02 March 2017 18:49:14
Good Evening from 'The Dockyard'.
I hope you're well?
Tonight's post will be focusing on the photo-etched brass tank lids /covers supplied with the part-works.
There are 7 in total to be fixed in specific places along the top of the port and starboard saddle tanks.
These covers are bolted on allowing easy removal when the U-boat is in dock and the tank internals have to be inspected due to damage or regular maintenance.
#289 Posted : 02 March 2017 19:02:26
The first of these 7 tank lids to be affixed is the No.2 Port Ballast Tank, which was often used as a fuel storage tank.
Referring to the instructions in the part-works the tank lid is positioned 3mm outwards of the casing [top deck].
The instructions suggest measuring this 3mm spacing with a rule which isn't quite accurate due to the saddle tank curving away. As 6 out of the 7 tank lids have to be fixed with the same 3mm spacing, measuring, especially when the casing curves in and out at various different points would prove to be time consuming too.
What I decided to do was to make a spacing tool from plastic strip 3mm wide. This meant that wherever I placed it against the lower sides of the casing, the tank lids, when glued up to my spacer would always be at the correct 3mm distance.
The attached photo shows No.2 Port Ballast Tank lid being fixed using my 3mm spacer.
#290 Posted : 02 March 2017 19:06:18
The previous photo actually shows No.2 Port Ballast Tank fixed in place and the next tank lid being glued up to my spacer; R1 Port Compensating Tank.
The attached photo shows a closer view of the R1 Port Compensating Tank lid. You can clearly see my spacer in this picture.
#291 Posted : 02 March 2017 19:10:44
Because of the very nature that the saddle tanks are curved, it became apparent that the flat, etched-brass tank lids would not adhere properly.
What I did was to gently bend them around a modellers knife handle to produce a gentle curve more in keeping with the curvature of the saddle tanks so that they would attain improved adhesion when glued.
The attached photo shows this method.
#292 Posted : 02 March 2017 19:17:07
The remainder of the tank lids for the port side were then fixed in place using my spacing tool whilst adding a slight bend to them from a knife handle as described previously.
There were 5 tank lids fitted to the port side; No.2 Port Ballast Tank, R1 Port Compensating Tank, R2 Port Compensating Tank, Port Crash Dive Tank and No.4 Port Ballast Tank.
Only two tank were fitted to the starboard side as the remainder are not visible due to the cut-outs showing the inside of the U-boat.
The two tank lids fixed on this side are; No.2 Starboard Ballast Tank and R1 Starboard Compensating Tank.
The attached photo shows No.2 Starboard Ballast Tank lid fitted, with part of it cut and filed off, to follow the contour of the saddle tank.
#293 Posted : 02 March 2017 19:20:26
This photo shows R1 Starboard Compensating Tank lid fixed. As i'm going to show the compartment directly beneath it to reveal the Junior Rates Mess and the Galley, I had to remove quite a bit of it so that it again followed the contour of the saddle tank.
#294 Posted : 02 March 2017 19:22:13
This photo shows all the port side tank lids fixed and glued in place.
#295 Posted : 02 March 2017 19:24:04
This photo highlights the two starboard tank lids in place and how I cut them to match the saddle tanks profile.
#296 Posted : 02 March 2017 19:25:10
This final image is more of an overhead shot including both port and starboard tank lids.
#297 Posted : 02 March 2017 19:30:35
Well that's it for tonight's post.
As a side note it is always worth considering making small jigs, tools or spacers for that matter to maintain accuracy, especially when faced with numerous repetitions of the same parts.
I have utilised this technique in it's various different forms whenever faced with such a task.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W
#298 Posted : 02 March 2017 19:47:06
Another nice update and great tips too.. look forward to seeing more...Drool Drool
#299 Posted : 02 March 2017 20:37:35
Thanks Alan! More posts to follow.
I'm really looking forward to the summer months when I can think about painting the hull!
#300 Posted : 03 March 2017 14:27:33
Very nice work ThumpUp keep them coming.
Chris Cool
This page was generated in 1.068 seconds.
