 Thought I would try this, Its water based so shouldnt go hard in the tube like the other stuff. will report on its quality's soon arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking forward to your report. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thats a new one on me. Like the idea of the water based product as i end up throwing away so many fillers through storage. Happy Modelling
Looks interesting, look forward to your results. Will you be testing it for sanding too?, as Its usually the sanding properties that let some of them down as they can tend to pit and leave a grainy finish. Steve
Always good to have another putty.I have been using plastic putty on the USAF planes and I really like it.Doesnt shrink, easy to apply and sands nicely
oooow not seen this one before, yes interested in your thoughts on that product Andy Jason “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Look forward to this Andy, just so happens I have been looking for some new putty as my green has gone off. I got £20 birthday money so new paint brushes and filler are coming my way.. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Squadron white and Squadron green are probably the most popular
 Hi All Used this a couple of times now it squeezes out like toothpaste has good gap filling quality's and sands back well. Be aware if it has a rubbery quality when sanding it needs more time to set properly. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,187 Points: 15,710 Location: ipswich
I use this stuff: Being made for proper automotive use, it doesn't shrink, sands really smooth and dries quickly. Also - you get a flippin' big tin for under a tenner. My tin is over a year old and is still soft and like new. (The contents - not the tin...lol) Mind you, I'll have a go with the one at the top of the post - it looks as if it could be very good. roymattblack attached the following image(s):
As a general rule of thumb, be mindful that some automotive fillers can soften or eat into model kit plastic., most standard types tend to be designed for use on metal and separate types for plastic or fibreglass use.
