 The meat goes on the bones and looking great. I do like the construction of this kit its almost like a secret gluing process that cant be seen after full construction very clever Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice update Alan  looking good. Al
Lovely start Alan, just a question though - I know this is a triple layer planking kit the same as my armed launch but was wondering why they have the inside (first) layer as limewood not walnut. Generally the layers would be walnut inside the hull, then lime in between and then walnut veneer outside  Or maybe this was just the case in the kit I have? Steve
[quote=magpie1832]Awesome Alan. Nice update and info on your progress. I will be watching your progress carefully as this is something I would love to attempt. I don't think my skills are three yet but will attempt one for sure. Thanks for sharing. Chris  [/quote Thanks Chris, I know with your skills you could take this one on no problem. All I say is that it is not a kit for the novice, experience is necessary.... She's a challenge in her own way.... Regards Alan
arpurchase wrote: The meat goes on the bones and looking great. I do like the construction of this kit its almost like a secret gluing process that cant be seen after full construction very clever Thanks Andy, the application of glue is one major item that will make this build a success or not. Just now I'm gluing quite sparingly where there s a chance of it being seen and later the first layer will be painted over with diluted PVA, the next planking layer being applied after that.... Regards Alan
Spal wrote:Nice update Alan  looking good. Al Thanks for looking in Al, appreciated... Regards Alan
stevie_o wrote:Lovely start Alan, just a question though - I know this is a triple layer planking kit the same as my armed launch but was wondering why they have the inside (first) layer as limewood not walnut. Generally the layers would be walnut inside the hull, then lime in between and then walnut veneer outside  Or maybe this was just the case in the kit I have? Steve Hi Steve, thanks for your comments appreciated...  .. This build is similar to the armed launch but is not the same. Your launch does have a triple layer of planking but this build only has two layers, the first with 1.5 x 6mm limewood and the second layer with 1.5 x 7mm limewood. Hope this answers your question... Regards Alan
Hi nice start to what looks a tricky build. Hope continues to go well for you. Cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
mogwai wrote:Hi nice start to what looks a tricky build. Hope continues to go well for you. Cheers mick. Thanks Mick, appreciated...  If all goes well then I think this is going to be a very interesting and enjoyable build.... Regards Alan
The build continues but at a slow pace now, has to be slow due to the way the planks are applied. All in all though, am really happy with how its going with 4 rows of planking now added and will say its starting to feel pretty solid. To help keep the plank in place I am able to pin at the edge of the plank and use the pin head to keep the plank against the rib until the glue on the plank edges sets. Once dry the pins can be removed and the plank stays in situ allowing the next plank to be added.....  .. Most of the time its waiting for the glue to dry thoroughly....Onto the next rows.... Happy building all... Regards Alan Gandale attached the following image(s):
 Rank: Amateur Level 1  Groups: Registered
I just noticed this build; it's nice to see something different. But, a few questions, if you don't mind: Do you have to taper the plank widths at the bow? And, do you have to bevel the plank edges to make them meet each other well along the curves? (I would think that it would make sense to measure the bulkhead distances from deck to keel at midships and at the bow and stern, and plan to taper the planks appropriately so that you wouldn't need to worry about drop planks, etc...) But, thanks for posting this build. I think it looks great so far.
Just had a catch up on this build, and as always, a superb display of craftsmanship! Top work Alan, I am sure your patience and skill will turn this into a stunning display piece when finished!
Really nice work Alan, she's starting to take shape now.
You can't rush quality and this is a quality build  nice work Alan. Al
RichieG wrote:I just noticed this build; it's nice to see something different. But, a few questions, if you don't mind: Do you have to taper the plank widths at the bow? And, do you have to bevel the plank edges to make them meet each other well along the curves? (I would think that it would make sense to measure the bulkhead distances from deck to keel at midships and at the bow and stern, and plan to taper the planks appropriately so that you wouldn't need to worry about drop planks, etc...) But, thanks for posting this build. I think it looks great so far. Hi Richie, thanks for looking in and your comments. The planks do have a bevel along their edge depending on where the meet the next plank along the length of the hull. Some of the planks also have a slight taper at the bow but every build does have its differences...  .. The build is being done as an OOB, no mention of droppers but will see how the build progresses.... Regards Alan
Nemesis wrote:Just had a catch up on this build, and as always, a superb display of craftsmanship! Top work Alan, I am sure your patience and skill will turn this into a stunning display piece when finished! Thanks Nem, patience is the one thing this build will need in abundance....  .. Appreciate you looking in and commenting..... Regards Alan
Thanks Graeme, Al and Andy for looking in and commenting, very much appreciated..... Regards Alan
This will turn out to be a great build and certainly interesting to watch it take shape. Regards, Phil W Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Hi Alan. Great looking kit. your planking so far is looking fantastic. looking forward to your next update. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
