37 Pages «<7891011>»
stevegbr
#161 Posted : 25 February 2017 23:03:13
panels secured with four screws.
stevegbr
#162 Posted : 25 February 2017 23:04:37
parts for issue 9.
stevegbr
#163 Posted : 25 February 2017 23:07:09
push the rim in to the tyre.
stevegbr
#164 Posted : 25 February 2017 23:09:10
put on the wheel cover, and secure with three screws.
stevegbr
#165 Posted : 25 February 2017 23:36:09
pushed in the centre piece and washer in to the wheel.
stevegbr
#166 Posted : 26 February 2017 12:30:22
here is the parts for issue 10.
stevegbr
#167 Posted : 26 February 2017 12:32:23
we first attach the left hand hub.
followed by the right hand side.
stevegbr
#168 Posted : 26 February 2017 12:34:07
then the front support bracket which is held by three screws.
stevegbr
#169 Posted : 26 February 2017 12:36:28
we then attach the steering rack, by putting the links through the openings.
as shown here, then secured by two screws.
stevegbr
#170 Posted : 26 February 2017 12:38:19
we then turn the chassis over to secure the track rod ends which require two screws.
stevegbr
#171 Posted : 26 February 2017 12:40:05
we then attach the bottom bracket, which is secured by four screws.
as shown below.
stevegbr
#172 Posted : 26 February 2017 12:41:59
next its the anti roll bar, which is secured by four screws.
as shown below.
stevegbr
#173 Posted : 26 February 2017 12:43:42
then we fit the two wheels to their hubs, which require two screws.
stevegbr
#174 Posted : 26 February 2017 13:48:54
here is issue 11.
stevegbr
#175 Posted : 26 February 2017 13:49:56
here are the parts for issue 11, this is the engine mounting.
stevegbr
#176 Posted : 26 February 2017 13:51:03
this is two brackets to assemble.
stevegbr
#177 Posted : 26 February 2017 13:52:05
the two support arms.
stevegbr
#178 Posted : 26 February 2017 13:53:31
two support brackets.
stevegbr
#179 Posted : 26 February 2017 13:54:56
now for the two covers.
stevegbr
#180 Posted : 26 February 2017 13:55:57
here is the engine mounting secured on the rear chassis.
Guest (7)
This page was generated in 0.398 seconds.
