according to the site its 390
so you will have:
Lenght 540mm Width: 390mm Height: 125mm
add 110mm on the legs so you will get: 235mm with the height
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
ElekTr1C wrote:according to the site its 390
so you will have:
add 110mm on the legs so you will get: 235mm with the height thanks for that, i looked but could not find the width.
Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
That is a great build. I am definitely going to be severely tempted to get this later in the year when it hits UK shores. It looks amazing as an OOB build, but I wonder if a little, select paintwork might improve things a little. As a huge GA fan, I have always had a soft spot for the original designs, and these look so good, I doubt I'll be able to resist becoming a subscriber. I am looking forward to more work as you progress. Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
three weeks to go, then i get some more parts for this build. cant wait.
nice :) still have 4 i need to do and will be getting 5 more next week :D
its a great and fun build :)
here is part 50 stevegbr attached the following image(s):
here are the parts for this issue. stevegbr attached the following image(s):
the pod supports are secured by a screw for each strut. stevegbr attached the following image(s):
the parts for the mole vehicle. stevegbr attached the following image(s):
parts attached. stevegbr attached the following image(s):
here is part 51. stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
the other three pod struts in place stevegbr attached the following image(s):
top support strut in place. stevegbr attached the following image(s):
here are the parts for the mole vehicle. stevegbr attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
The Mole looks really nice - except for the seam line right through the 'drive belts' along the sides. Could they be sanded off, or even replace the belts with correct size cable tie strips?
I really want TB2 if it hits the UK.
Really is a great build Steve  looks a very detailed kit  love how everything seems to fall together  i`d like to build it but can not afford so at the moment  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
It should be availble here this year phil. Then make a decision.
Message was deleted by User.
