Gratings question for tomick Options
saintsman123
#1 Posted : 23 February 2011 23:41:47
Just a little thing Tomick, just in case it causes confusion, in the latest post you say that the medium grating is 10 by 10, thats ok notch wise, but it ends up as a 9 by 9 grid of complete squares, or 11 by 11 with the outer edges included. I only mention in case someone makes a grid with 10 by 10 squares. I hope you get my meaning, and as per usual is no disrespect is meant for any build
Come on you Jimmies
#2 Posted : 24 February 2011 09:36:02
The 10x10 reference is regarding notches and is exactly what is noted in the magazine, its unlikely there will be any confusion if the grating strips are correctly cut simply because the grids are bespoke to the large and medium gratings and the two small garting are identical.
This page was generated in 0.074 seconds.
