13 Pages <1234>»
Panart 1/16 Victory Sloop Build Options
#21 Posted : 19 February 2017 01:08:31
BigGrin The meat goes on the bones and looking great.
I do like the construction of this kit its almost like a secret gluing process that cant be seen after full construction very cleverCool
#22 Posted : 19 February 2017 09:38:58
Nice update Alan Cool looking good.
#23 Posted : 19 February 2017 09:49:48
Lovely start Alan, just a question though - I know this is a triple layer planking kit the same as my armed launch but was wondering why they have the inside (first) layer as limewood not walnut. Generally the layers would be walnut inside the hull, then lime in between and then walnut veneer outsideConfused Or maybe this was just the case in the kit I have?
#24 Posted : 19 February 2017 11:29:13
[quote=magpie1832]Awesome Alan. Nice update and info on your progress. I will be watching your progress carefully as this is something I would love to attempt. I don't think my skills are three yet but will attempt one for sure.
Thanks for sharing.
Chris Cool [/quote
Thanks Chris, I know with your skills you could take this one on no problem. All I say is that it is not a kit for the novice, experience is necessary.... She's a challenge in her own way....Cool Cool
#25 Posted : 19 February 2017 11:37:03
Thanks Andy, the application of glue is one major item that will make this build a success or not. Just now I'm gluing quite sparingly where there s a chance of it being seen and later the first layer will be painted over with diluted PVA, the next planking layer being applied after that....Cool Cool
#26 Posted : 19 February 2017 11:37:59
Thanks for looking in Al, appreciated...
#27 Posted : 19 February 2017 11:45:02
Hi Steve, thanks for your comments appreciated...Cool Cool .. This build is similar to the armed launch but is not the same. Your launch does have a triple layer of planking but this build only has two layers, the first with 1.5 x 6mm limewood and the second layer with 1.5 x 7mm limewood. Hope this answers your question...
#28 Posted : 19 February 2017 11:48:36
Hi nice start to what looks a tricky build. Hope continues to go well for you. Cheers mick. BigGrin
#29 Posted : 19 February 2017 11:52:58
Thanks Mick, appreciated...Cool Cool If all goes well then I think this is going to be a very interesting and enjoyable build....Cool Cool
#30 Posted : 23 February 2017 23:23:18
The build continues but at a slow pace now, has to be slow due to the way the planks are applied. All in all though, am really happy with how its going with 4 rows of planking now added and will say its starting to feel pretty solid. To help keep the plank in place I am able to pin at the edge of the plank and use the pin head to keep the plank against the rib until the glue on the plank edges sets. Once dry the pins can be removed and the plank stays in situ allowing the next plank to be added.....Cool Cool .. Most of the time its waiting for the glue to dry thoroughly....Onto the next rows....
Happy building all...
RichieG
#31 Posted : 28 February 2017 20:16:24
Rank: Amateur Level 1
I just noticed this build; it's nice to see something different.
But, a few questions, if you don't mind:
Do you have to taper the plank widths at the bow? And, do you have to bevel the plank edges to make them meet each other well along the curves?
(I would think that it would make sense to measure the bulkhead distances from deck to keel at midships and at the bow and stern, and plan to taper the planks appropriately so that you wouldn't need to worry about drop planks, etc...)
But, thanks for posting this build. I think it looks great so far.
#32 Posted : 28 February 2017 20:36:45
Just had a catch up on this build, and as always, a superb display of craftsmanship! Top work Alan, I am sure your patience and skill will turn this into a stunning display piece when finished!BigGrin
#33 Posted : 28 February 2017 21:01:14
Really nice work Alan, she's starting to take shape now.
#34 Posted : 28 February 2017 21:09:04
You can't rush quality and this is a quality build Cool nice work Alan.
#35 Posted : 28 February 2017 22:32:00
BigGrin Looking the bizzDrool Drool Drool Alan and very nice workCool
#36 Posted : 28 February 2017 22:58:55
Hi Richie, thanks for looking in and your comments. The planks do have a bevel along their edge depending on where the meet the next plank along the length of the hull. Some of the planks also have a slight taper at the bow but every build does have its differences... Cool Cool .. The build is being done as an OOB, no mention of droppers but will see how the build progresses....Cool Cool
#37 Posted : 28 February 2017 23:02:07
Thanks Nem, patience is the one thing this build will need in abundance.... BigGrin BigGrin .. Appreciate you looking in and commenting.....
#38 Posted : 28 February 2017 23:03:22
Thanks Graeme, Al and Andy for looking in and commenting, very much appreciated.....Cool Cool
#39 Posted : 01 March 2017 10:17:16
This will turn out to be a great build and certainly interesting to watch it take shape.
Phil W
#40 Posted : 01 March 2017 12:42:51
Hi Alan.
Great looking kit. your planking so far is looking fantastic. looking forward to your next update.
Ian Cool Cool BigGrin Drool
13 Pages <1234>»
This page was generated in 0.194 seconds.
