Some nice detail in the resin parts. Hope there`s not too much work for you to get the resin to fit.  Looking forward to next update. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Really nice start Carl. Looks nice and clean with lots of nice detail I'm sure this will be another great build to follow
That`s a great looking cockpit Carl cracking job  look forward to your next update  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
These are coming along well. Great work being shown.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Thanks everyone, F84FI glued in the front of the nose piece.This includes the landing gear bay for the front wheel.There is a steel ball in this piece which prevents the model being a tail sitter.The resin cockpit doesnt fit with the landing gear piece so I sawed off some of the rear of the landing ear piece.I also painted the sidewalls.The resin cockpit doesnt fit that well so it will need a bit of fiddling around to get it in the right spot and get the fuselage sides to mate up properly. darbyvet attached the following image(s):
F84FThe resin cockpit tub is fitted.As you can see it was a very tight fit.I spent an hour fiddling to get the instrument panel fitted and the fuselage sides glued together.next step is to deal with the fuselage seams and start spraying the metal .I will be using Tamiya lacquer for this plane with some metalizer for the exhaust. darbyvet attached the following image(s):
Good job Carl  cockpit looks great. Al
F84-GThe f84f is now having its seams fixed and soon will go to paint so I started on the Taimya f84g.This will be an out of the box build.The cockpit is pretty nice. This kit is already painted in silver paint.I plan on seeing how it looks without paint.The wingtip fuel tanks need to be painted so I built them and sanded off the paint. darbyvet attached the following image(s):
Carl Looking forward to your Tamiya build as i have that metal finish kit in my collection so interested to see how you work with this one. Happy Modelling
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Very nice update Carl, look forward to seeing how it all turns out.... Regards Alan
Making good progress Carl, great job
I think your going to be fed up with spraying silver and white colours by the time this build project is over Enjoying seeing it progress though. Al
Looking good. Brave move to strip the paint and start from fresh, but I`m sure you`ll get it to the next level. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Carl.  looking good  Ian. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thanks everyone, So I got an F100C kit.It was Trumpys 1/48 kit.I compared it to the F100D kit.It is almost identical except for the tail.There are no F100c thunderbirds decals, but I think I can use the F100D set that warbirds decals sells and use a bit of red paint to make the tail decal work.here are the two fuselages.The F 100C is the lower one. darbyvet attached the following image(s):
F16I am in the process of selling some of my plastic kits and I found I already had a 1/48 F-16 Thunderbird kit, so I now have 2 of these with eduard cockpit sets.So I figured I will build one plane in flight and one on the ground.There are typical Tamiya quality.Excellent detail and perfect fit so far. Carl darbyvet attached the following image(s):
F100CI started work on the F100C and D. I bought eduard cockpit sets for both.Unfortunately I bought a 1/72 set for the F100D which obviously doesnt fit the 1/48 cockpit.oops. Anyway here is the f100C cockpit with the eduard detail set added. Carl darbyvet attached the following image(s):
I love that upgrade kit, it looks very good. Nice work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Great update Carl  is that the self adhesive Eduard set you`ve used ?regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Guest (8)
