Joined: 24/01/2017 Posts: 3 Points: 9 Location: Arizona
I've just started my build and have ordered the paint set. Is there a list of component colors for the HMS Sovereign? Dwight
Hi Dwight, welcome to the forum.I am forum support for USA.I am not exactly sure what you are asking.The instructions tell you which parts to paint.
Welcome to the forum Dwight, am sure you'll love putting the SOTS together... Would also recommend you take a look and follow the official build closely, it will give you all the information you need.... Regards Alan
Welcome to the forum. I hope you enjoy your build, it's a great kit and will build into a superb model. There is plenty of help on the forum should you need it.
Hi Dwight, Welcome to the forum. I`m sure you`ll love the Sots build, it`s a great choice. There is a mountain of tips and advise here to help you on your way, but should you not find what you need just ask. Someone will come to your rescue. Hope you will start a build diary so we can see how you progress. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Welcome to ModelSpace, hope you enjoy your time with us and your build
Welcome to the forum Dwight, good luck with your build - a very nice choice Steve
 Nice choice and welcome to the forum Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Welcome to the forum Dwight. look forward to seeing your work.
Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Welcoming me to the forum Dwight, hope you enjoy building the Sovereign
Thanks for the responses. In Pack 1 the cannon carriages are painted red, looking at completed models the carriages may be yellow or wood color. I'd like to build an accurate Sovereign, are the colors in the instructions the most accurate ones?
Dwight
 Hi Dwight the colours of the gun carriages are a bit of a speculation as no plans or drawings are available for this ship and lots of captains had their own ideas on painting but red was a popular colour  . I stained mine a brick red colour so the wood showed through. Hope this helps rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Dwight U Phillips wrote:I'd like to build an accurate Sovereign This may be impossible. Pretty much every model of the Sovereign is based on the Robert Sepping model of 1830. Unfortunately that model does not actually feature the stern gallery of the actual Sovereign of the Seas, but instead an approximation pretty far removed from the actual thing. The real stern gallery as it was worn by the Sovereign can be seen in the 1645 painting "Peter Pett and the Sovereign of the Seas" http://collections.rmg.c...tions/objects/14422.html
Thanks guys for the enlightenment on colors. It sounds like following the plan colors I should be representative of the original Sovereign. Super.
It is often very hard to know exactly what the original ship looked like.In many cases the original plans no longer exist and the models are therefore based on paintings or illustrations combined with books covering ship construction etc.... it is also not uncommon for a museum model to be used by many others at the benchmark for accuracy when in fact even the museum model was made using the same assumptions and varied sources for information.
Look forward to seeing your Build. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
