6 Pages 123>»
Andreas modified T-72 Options
Andreas
#1 Posted : 31 January 2017 18:04:49
Groups: registriert
Hi everyoneBigGrin
Now we are also happy too have the T-72 in Germany. So i started my own Project, and once again by using Watertransferpressure. I want to change the Comouflage.I do not want anything off the shelf, so I start my modified T-72 tank. I did it once with the Hummer H1,and it was nice to do something else instead of working with Paint. Till now i didn´t put all Parts together because the Parts have to be dismantled anyway. The only thing I have changed at the moment are the brass bushings of the idle Wheel against needle bearings. Then i assembled the track links an pins so far. Last but least i modified the Searchlight.
Now i am just waiting for the transfer foil. It is ordered so the parts should be dipped soon. The camouflage is a modern pattern, but even today, the T-72 are still modernized in some countries, I think everyone should calmly leave his imagination free run,by building and modifying his T-72.BigGrin
I have now started to prepare the first components for transfer printing, by putting on the base color on the Parts. It is important that the base color fits with the transfer film. By this film I took the basic color must be white. Depending on the color, the basic color of the components is always indicated. I will work on the attachments only with 3 colors, white black and brown. The transfer foil which I need in the size costs 5 euros. But slightly cheaper than spray colors. I already have a lot of experience with water transfer printing, and i think it will work out BigGrin. The first pic just shows which pattern it is goiing to be on the T-72.
Forum Support Team
#2 Posted : 31 January 2017 19:20:54
Great start Andreas, like the colour scheme your planning Cool
#3 Posted : 31 January 2017 19:54:23
Nice start to your build, looking forward to seeing how the camo turns out. I am doing digital on mine, but spraying it.BigGrin
#4 Posted : 01 February 2017 01:31:59
Great start Andreas Cool
It's really good to see another customised T-72'being done
Andreas
#5 Posted : 01 February 2017 04:38:34
Groups: registriert
Thank you Dave, Nem
But of course I also follow your modifications. I like to learn.BigGrin
I do not always like things off the shelf, so I try to change them.BigGrin
Forum Support Team
#6 Posted : 05 February 2017 17:35:10
What size roller bearings did you use for the drive sprockets?BigGrin
#7 Posted : 05 February 2017 17:54:38
#8 Posted : 05 February 2017 19:02:27
looking forward to seeing your paint finish. It looks a complicated one but a good one.
Hope it all goes well for you.
#9 Posted : 05 February 2017 20:04:52
Looking good, very nice work...Drool Drool
Andreas
#10 Posted : 09 February 2017 11:04:36
Groups: registriert
I can´t start with my watertransferprinting to change the camourflage, untill i receive the second delivery. There are still several parts i need as for example the Hull . So i decided to work on the other Parts as the Commanders hatch, the Containers,stowage Bins and the External Fuel Drum. I first changed the original Colours into brown,and then started painting them again. My new camourflage is going to be Brown ,Black and white. I think it would work out nicely with the brown and black parts. The next step i also allready done ist to put in a Working Searchlight. By the figur it was necessary for the painting to take of his arms,and so i decided to change the angles of the arms. That´s it, the first steps are done, so wait until delivery 2 arrives ,and do some another modifications.BigGrin
Forum Support Team
#11 Posted : 09 February 2017 15:34:37
Great start on the repainting of the parts Andreas, really love what you did with the search light Love Cool
#12 Posted : 09 February 2017 15:49:57
Great update, the searchlight is one of the mods I will be adding. Nice work.BigGrin
Andreas
#13 Posted : 09 February 2017 17:43:20
Groups: registriert
Thanks Nemesis,Davetwin
Thanks I appreciate it very much. Yes the searchlight must be. But I am happy to work with watertransfer printing again. Modifications also will still follow, I'm not quite finished yetBigGrin
Andreas
Forum Support Team
Andreas
#14 Posted : 16 February 2017 17:58:07
Groups: registriert
Now just after receiving the Watertransfer foil, I started with changing the camouflage off the first parts I already received off the Tank.
Firstly it is important that the temperature of the water is at 30 degrees. The next step is that the foil you cut off is big enough to cover the Parts. When you work with this stuff, it is very important to wear rubber gloves. When you don’t wear them, your hands are going to look very smart when your hands are covered with the camouflageBigGrin . The problem with the foil is it goes into every pore, and to remove it again is very hard. It isn’t dangerous, but it looks funny. The only thing that has to be considered in the process is when you spray the activator onto the film you should wear a Breathing mask. So I started. The first part I dipped was the cannon tube. I think it came out pretty well. The next part was the turret. This part has got a lot off corners and niches. Therefore, it is important to dip such parts in a 45 degree angle. Now the first part off the Job is done, and I am now waiting for the next parts to come.
Forum Support Team
#15 Posted : 16 February 2017 18:22:53
Now that looks supercool, well done Andreas ThumpUp
#16 Posted : 16 February 2017 19:05:38
That looks really good, we use hydro dipping on motor bike parts, wheels and body panels. Excellent update. BigGrin
Andreas
#17 Posted : 03 March 2017 21:51:45
Groups: registriert
Hi Guys
here we go againBigGrin
After receiving the second delivery the came startet again,and i could handle the upper hull with water transfer Printing. This time everything went smooth. If you handle big parts it sometimes ends with little Problems. But this time everything went fine. The work is done ,but not finally. Now all the details must be worked out on the surface. The hinges, covers, hatches, etc.I think i´ll take black or perhaps Brown to paint all the Details. And again, another step is doneBigGrin
Forum Support Team
#18 Posted : 03 March 2017 23:43:10
Now that's looking great, fab work....Cool Cool
eebygum
#19 Posted : 04 March 2017 00:10:59
That looks superb good job Well done BigGrin
Rgds
Terry
#20 Posted : 04 March 2017 00:14:21
Awesome transformation of those parts Andreas ThumpUp great update.
6 Pages 123>»
This page was generated in 0.217 seconds.
