Dwight U Phillips Options
Dwight U Phillips
#1 Posted : 26 January 2017 16:53:47
Rank: Newbie
I've just started my build and have ordered the paint set. Is there a list of component colors for the HMS Sovereign?
Dwight
#2 Posted : 26 January 2017 17:26:52
Hi Dwight,
welcome to the forum.I am forum support for USA.I am not exactly sure what you are asking.The instructions tell you which parts to paint.
#3 Posted : 26 January 2017 20:18:16
Welcome to the forum Dwight, am sure you'll love putting the SOTS together... Would also recommend you take a look and follow the official build closely, it will give you all the information you need.... Cool Cool
#4 Posted : 26 January 2017 21:31:50
Welcome to the forum. I hope you enjoy your build, it's a great kit and will build into a superb model. There is plenty of help on the forum should you need it.
#5 Posted : 27 January 2017 00:54:33
Hi Dwight, BigGrin
Welcome to the forum. Cool
I`m sure you`ll love the Sots build, it`s a great choice.
There is a mountain of tips and advise here to help you on your way, but should you not find what you need just ask. Someone will come to your rescue.
Hope you will start a build diary so we can see how you progress.
#6 Posted : 27 January 2017 11:00:30
Welcome to ModelSpace, hope you enjoy your time with us and your build Cool
#7 Posted : 27 January 2017 12:41:08
#8 Posted : 27 January 2017 18:59:12
BigGrin Nice choice and welcome to the forumCool
#9 Posted : 27 January 2017 19:53:31
Welcome to the forum Dwight. look forward to seeing your work.
Cool
#10 Posted : 27 January 2017 21:09:52
Welcoming me to the forum Dwight, hope you enjoy building the Sovereign Cool
Dwight U Phillips
#11 Posted : 29 January 2017 16:27:31
Rank: Newbie
Thanks for the responses. In Pack 1 the cannon carriages are painted red, looking at completed models the carriages may be yellow or wood color. I'd like to build an accurate Sovereign, are the colors in the instructions the most accurate ones?
Dwight
#12 Posted : 29 January 2017 16:40:13
BigGrin Hi Dwight the colours of the gun carriages are a bit of a speculation as no plans or drawings are available for this ship and lots of captains had their own ideas on painting but red was a popular colour Cool . I stained mine a brick red colour so the wood showed through. Hope this helps rgd Martyn
greyhawk
#13 Posted : 29 January 2017 16:47:36
This may be impossible. Pretty much every model of the Sovereign is based on the Robert Sepping model of 1830. Unfortunately that model does not actually feature the stern gallery of the actual Sovereign of the Seas, but instead an approximation pretty far removed from the actual thing.
The real stern gallery as it was worn by the Sovereign can be seen in the 1645 painting "Peter Pett and the Sovereign of the Seas"
http://collections.rmg.c...tions/objects/14422.html
Dwight U Phillips
#14 Posted : 01 February 2017 17:35:41
Rank: Newbie
Thanks guys for the enlightenment on colors. It sounds like following the plan colors I should be representative of the original Sovereign. Super.
#15 Posted : 01 February 2017 17:45:10
It is often very hard to know exactly what the original ship looked like.In many cases the original plans no longer exist and the models are therefore based on paintings or illustrations combined with books covering ship construction etc.... it is also not uncommon for a museum model to be used by many others at the benchmark for accuracy when in fact even the museum model was made using the same assumptions and varied sources for information.
#16 Posted : 02 February 2017 13:16:21
Look forward to seeing your Build.
Ian Cool BigGrin
This page was generated in 0.426 seconds.
