19 Pages 123>»
jonny7england build. Options
jonny7england
#1 Posted : 14 February 2011 17:52:54
I've been a member od this forum for a year now but have not contributed a build log. A bit late? Perhaps, but there are some of our shipmates that are late starters, so this is for them.
So here goes...starting with the bow section and the first of the frames.
Son of Bulwark
#2 Posted : 15 February 2011 17:19:36
Hi jonny! Cool
It doesn't matter when you start a build dairy, I'm just glad you have. I found it a great help, it makes you think what you're doing and the brake from building can save you from rushing ahead. It's good to stop and reflect on your work, keep the rest of us upto date on your build.
Good luck mate!
jonny7england
#3 Posted : 21 June 2011 20:40:03
A very handy tool to have...just cost a fiver...Handy for those delicate shaping jobs...BigGrin
Zeptrader
#4 Posted : 22 June 2011 09:50:28
got me one of those a few months back, well worth having.
How are you getting on with the planking Jonny?
jonny7england
#5 Posted : 22 June 2011 10:27:30
Hi Colin...yeah. it is a terrific little tool...and as for the planking, I can happily say... WHOOPEE!!! Completed it, now I am on the lower wales section...I hope to get some pictures up here soon...
BigGrin
Zeptrader
#6 Posted : 22 June 2011 11:18:26
good news mate, Im starting again as of yesterday (back to work tomorrow) but I wish I kept to the planks supplied arghhh!!!! these 2mm planks are taking forever, I guess it will look good in the end but I see NO END..BigGrin
#7 Posted : 22 June 2011 12:28:33
Jonny your builds looking great, looking forward to the photos of the planking. ( Thank goodness I`ve finished mine )BigGrin
Son of Bulwark
#8 Posted : 22 June 2011 12:28:50
Hi jonny7england! Cool
It is a good little plane and a lot safer than a razor plane, you will be glad that the lower planking is done mate! I know that WHOOPEE!!! feeling.
jonny7england
#9 Posted : 22 June 2011 17:31:10
The frames all squared up, then came the lower gun deck...
More picture of my build diary to follow...time enough to sneak off for a cuppa...Drool
Zeptrader
#10 Posted : 22 June 2011 17:45:00
keep 'em coming Jonny
Wilfy the Sea Dog
#11 Posted : 22 June 2011 18:03:08
Hi Johnny,
Looking good mate, keep it up.
Can I ask where you purchased the mini plane?
Thanks
Wilfy
jonny7england
#12 Posted : 22 June 2011 18:39:18
Oh look, more decking, and I though I had got away with just fitting one???-Blink
jonny7england
#13 Posted : 22 June 2011 19:04:48
Wilfy the Sea Dog wrote:
Hi Johnny,
Thanks
Wilfy
Try this...
http://www.toolsdiy.co.u...ions.price,ASC&qS=46
jonny7england
#14 Posted : 23 June 2011 10:57:50
Here are some more deck pictures plus that of the gallery supports..
And here you can see the infamous Rib 15 that many of us had problems with...Easilly sorted, as you will see in upcoming pictures...
Now the gallery supports are fitted here..
That's all for now shipmates...More pictures to come soon...BigGrin
jonny7england
#15 Posted : 23 June 2011 12:33:43
In my last posting I mentioned the infamous Rib 15 and here is how I dealt with it? There needed to be some build up of frames where they had to be level with the false keel, and also in places where the planking would need to come into contact with the frames...these areas I used spare strips of 2mm x 1mm planking super glued to the frames where needed and sanded down.
And then the faring commenced stern to bow using a spare length of wood to ensure that the planking would fit evenly onto the frames? Well that's the lot for now shipmates..More to come...Happy building...
BigGrin ThumpUp
ajbird74
#16 Posted : 23 June 2011 14:32:05
Hi Johnny
Which technique did you use to pull that troublesome rib 15 back online?
This is the thing that's still holding me back on my build.
Your build is looking very good.
Kind regards
jonny7england
#17 Posted : 23 June 2011 14:49:57
Once more into the breech...I side view with the first line of gun ports marked out:
She's taking shape...now, how many among you, who are absent minded as me, got it in mind to measure two or three timesc and only cut once? So I have this habit of writing the measurements down on the hull itself as I go along??? From here on, the hull begins to a wooden note pad than a ship...
LOL
Now to cut the gun ports out...How many did you say???...Blink
She's never going to float with all them holes in her...LOL
Onwards and upwards...Laugh
jonny7england
#18 Posted : 23 June 2011 14:58:23
ajbird74 wrote:
Hi Johnny
Kind regards
Thanks for the comments...I have built up rib 15 where needed on the outside and on the inside where the top of rib 15 took an inward direction...I gently sanded it back, but always checking with each layer of planking that I applied...so far, it has not been too much of a problem..Hope I have helped???
BigGrin
jonny7england
#19 Posted : 23 June 2011 15:44:09
The second row of gun ports are completed and planking continues:
Yet another row of ports cut into place...and by this time, I began to suffer serious knuckle cramp...Blink
Oh well, work continues??
Okay, it's not perfect...But I'm getting there!!
Oh well...can't build up any more, so I best head downwards...Huh
Adding some lining to the gun ports...Oh Lord it looks rough...but when sanded...well, you heard tghe story about the ugly duckling...haven't you???
And after running into problem after problem...planks not sitting right, planks not so wide or as thick as I expected, I plodded on...Blink
[img]
jonny7england
#20 Posted : 23 June 2011 16:05:58
I can see light at the end of the tunnel...But seriously,a shed load of sandpaper and filler were constantly on my mind at this point in time...Blink
Okay....at this stage...now considering putting in a take-over bid for the Pollyfiller company...Blink
Well...the show must go on??? Keel fitted..Stem and Stern posts in place...Now for the gallery...Huh
19 Pages 123>»
This page was generated in 0.186 seconds.
