2 Pages <12
Nems Customised RC T72 Tank Build. Options
#21 Posted : 28 January 2017 17:06:18
So, first up is to replace the cast conduits with soft brass rod. I will be using 2 different diameters for this and soft solder wire for the connections to the smoke grenade launchers and search lights. These will be fitted later in the build as I also have weld seams to add with Mr Surfacer and putty.
So to start I drilled a hole to allow the new conduit to enter the turret. This will have a weld seam, as will where it meets the junction box. Next was to carefully remove the cast conduit with the Dremel. I am not to worried about any marks left, as the turret will have a surface added all over. Brass rod was then put through the hole and bent to fit the contours of the turret and filed to fit the junction box, again, weld seam to be added. The new conduit then had thin super glue flowed along it to secure it in place. 1 down, 5 to go!BigGrin
#22 Posted : 28 January 2017 17:54:28
Good start Nem BigGrin
#23 Posted : 28 January 2017 19:19:47
BigGrin Nice startCool
#24 Posted : 28 January 2017 19:22:49
Hi very nice start. Look forward to your mods on this kit.cheers mick. BigGrin
#25 Posted : 28 January 2017 19:26:37
Nice Start Nen, I'm looking forward to following this build. BigGrin ThumpUp
#26 Posted : 28 January 2017 20:45:37
Hi all and thanks for looking in and your comments.BigGrin
The main conduits are now done. The others will be done as parts are added so I can place them correctly, and the wires will be added when I get the smoke grenade launchers. Next up was to remove the seams from the snorkel tube and start filling and adding welds, and also the seams and fill the gaps on the figure.BigGrin
#27 Posted : 28 January 2017 21:18:29
Great work Nem, look forward to following your next update....Cool Cool
#28 Posted : 28 January 2017 22:14:08
Very nice start, love the electric conduits Drool
#29 Posted : 01 February 2017 20:23:15
Thanks for looking in everyone. BigGrin
Not much to show, but I am building up the welds and filling some gaps around the turret lifting hooks and view finder.BigGrin
#30 Posted : 01 February 2017 22:36:39
Nicely done Nem, you keep posting and I'll keep following....BigGrin BigGrin
Andreas
#31 Posted : 02 February 2017 07:08:37
Groups: registriert
Great,BigGrin ThumpUp I'm really excited about your modifications.This is really impressive gonna follow your modifications on any case
Forum Support Team
#32 Posted : 02 February 2017 23:10:09
Thanks for your comments.BigGrin
The figure has had a coat of primer and I think he will do for now, just a few minor tweaks, but he needs a name!LOL BigGrin
I have given the turret a coat of primer also, it shows up any additional work I need to do, and i can see some parts that need work.BigGrin
#33 Posted : 02 February 2017 23:40:25
Looking good Nem Cool what about Boris or Igor.
#34 Posted : 24 February 2017 11:44:27
Boris sounds good!LOL BigGrin
Not much to report at the minute, just lots of filling and sanding to remove seams and join lines ready for priming.BigGrin
#35 Posted : 21 March 2017 21:13:46
Not much to show at the moment, more sanding and priming and sanding and priming!LOL BigGrin All seams and gaps gone, now onto the next issues for the same treatment.BigGrin
#36 Posted : 21 March 2017 22:02:53
BigGrin Very nice work as you say its the prep that pays all the dividends when doing paintingCool
#37 Posted : 21 March 2017 23:58:21
Very nice upgrades Nem, certainly improves from the original model.
Chris Cool
2 Pages <12
This page was generated in 0.459 seconds.
