7 Pages <12345>»
Kevs' 1:20 Senna McLaren MP4/4 Build (Superdetailed) Options
michu
#41 Posted : 17 January 2017 13:55:27
This is awesome, I love your additions to this build!
Happy building :-)
#42 Posted : 17 January 2017 20:54:01
Thanks Michal, pleased you like what I'm doing and thanks for looking in on my build, very much appreciated. Cool ThumpUp
Looking forward to seeing more of your Porsche Carrera GT build, you're doing a very nice job of that I must say, well done. Drool ThumpUp
#43 Posted : 18 January 2017 22:41:37
Hi Kev.
Fantastic start to your build. will be watching with great interest.
Look forward to the next update. Ian Cool BigGrin
#44 Posted : 18 January 2017 23:39:26
Well done Kev! Some beautiful work and re-arranging going into this one, and some trademark scratch building too!Cool Cool Cool
You can tell I know nothing whatever about racing cars - when I saw MP4/4 in the title I thought you were building a large scale German Assault rifle! (Then I noticed the Senna and McLaren!Blushing )
I bet your eyes will be burning like mine were after the ring mail looking at the size of those add ons!BigGrin
Best of luck with her!
Robin.
#45 Posted : 02 February 2017 06:30:29
Hi Kev. I'm eagerly awaiting the progress on your build and still trying to figure out the missing part or parts? Perhaps another cryptic clue?Confused
I found the battery by the way. It's on the front of the left hand intercooler ducting.
#46 Posted : 16 July 2017 16:53:34
Hello all,
Found some time to make a little more progress on this.
When I last updated I was working on the basic engine/gearbox build and the upper rear suspension arms and a couple of other bits, but I'm not going to show that work in this update as I want to leave the engine/gearbox assembly just for a little while and come back to it later. I want to do some work on other areas of the model for a while, but will do small pieces to the engine/gearbox in between and will show the work as I do it, but probably leaving the final engine assembly until nearer the end?
Using 'Krick' metal blackener, I have blackened the driveshafts, which were supplied in my upgrade set as plain machined brass bar. These can be seen in the first photo below. Not sure why they are portrayed as being a copper/bronze colour in the kit instructions and also in the DeAgostini 1:8 version of this car, as every reference photo I have seen shows them as being a metallic black and I prefer to stick with what is on the real car?
I have also assembled and painted the rear shock absorbers which are supplied as part of the upgrade set and come as a resin body with a turned aluminium upper part and a blackened metal spring, much better than the one-piece kit part from Tamiya! I did have a photo of the parts before construction but can't locate it anywhere so it's just the one photo below I'm afraid? There will be other scratchbuilt parts added to the shock absorbers at a later date before I fit them to the sideds of the gearbox.
Moving on to other parts of the build, I have decided to start constructing the wheel hubs, brake discs and brake calipers. The upgrade set provides complete replacements for these and none of the Tamiya kit parts are used in the construction. The photo below shows all of the parts needed to construct just one wheel hub/brake disc assembly and consists of no less than 21 pieces for EACH one, and even includes etched metal locking wires for the hub bolts! The dull metallic piece of wire in the centre-right of the photo is a piece of 0.6mm soldering wire which has to be cut into eight slightly over-length pieces then glued into the eight circular indents around the edge of the two steel coloured star-like discs on the left of the photo once they have been glued to each other. These pieces of wire are then cut and sanded down to size to portray a ring of bolt heads and then the brass coloured star shaped disc is glued behind and the etched locking wires then glued on top - quite ingenious and very effective I think? The photos show the first hub/brake disc assembly before and after construction but I now have another three to do after this, so that's a total of 84 parts just to build four assemblies and that doesn't include the brake calipers! Penny shots are included to show the small size of these in 1:20 scale! I am super impressed with the look of the replacement assemblies and in my next update I will show all four constructed units along with the brake calipers as well, and if I get time, hopefully everything will be painted.
Thanks for looking, all comments and criticisms welcomed.
ModelMania attached the following image(s):
michu
#47 Posted : 17 July 2017 00:22:19
This upgrade set is awesome, man. Really great job. What are you using for references? Internet pictures or some book?
I had a hard time recently finding time or motivation for the builds - when I had time, it was too hot to move a finger, and now I'm again lacking time :( But I did manage to finish the Porsche, have you seen my finished build gallery? http://forum.model-space...aspx?g=posts&t=23510
Happy building :-)
#48 Posted : 17 July 2017 10:49:04
Thanks for your really nice comments Michal, very much appreciated. Cool ThumpUp
My main reference material is the Model Factory Hiro (MFH) book which is dedicated to this car and there is a picture of it in my post #1 of this diary? It contains a wealth of very useful photographs and I can highly recommend it to anyone building a model of the McLaren MP4/4.
I have just had a look at your Porsche build Michal (don't know how I missed it!) and it is stunning, very well done indeed!! Drool Drool ThumpUp
#49 Posted : 20 July 2017 16:24:41
Hello all,
Finally finished building all four of the brake disc/hub assemblies (84 pieces in total!) from the upgrade set, photo can be seen below. Next job is to prepare and prime the calipers and their associated hydraulic piping and unions.
I've also added a few more PE parts to the engine and gearbox which can be seen below. The 'Honda' badges on the cam covers were already attached in a previous update, but I wasn't happy with the way they were sitting so I sliced them off and re-attached them.
I have also assembled and primed the resin upper rear wishbone assembly which comes in the superdetail set and which replaces the plastic kit part. I did have a photo of the component parts before assembly, but can't find it so I can only show it as assembled and primed, but I've indicated on the photo what work has been done? Needed a fair bit of Mr Surfacer 500 and sanding on the wishbone parts to tidy them up as they are not the neatest of mouldings which was a little disappointing given the cost of the set!!
#50 Posted : 21 July 2017 13:14:55
Great update kev BigGrin has really got some small etch workBigGrin superb jobDrool regards PhilCool
michu
#51 Posted : 21 July 2017 13:47:00
Way to go, Kev! These discs look awesome, you did a really good job of them.
Happy building :-)
#52 Posted : 21 July 2017 22:57:21
Great work Kev, very impressive....Drool Drool
#53 Posted : 22 July 2017 07:14:45
Hi Kev. Great to see your progress on this build. Those wheel hubs and discs look fantastic.Cool
Super neat job from you as always.
#54 Posted : 23 July 2017 15:52:06
Thanks Phil, Michal, Alan and Malc for looking in and for your nice comments always greatly appreciated. Cool ThumpUp
Some of these etch parts are almost microscopic and close to the limit of whether or not I can fit them and still keep things neat and tidy without any glue showing - definitely a challenge, that's for sure!! Huh Blink
michu
#55 Posted : 23 July 2017 18:00:34
What I found out, the Mr Metal Primer works great if you need to glue tiny photoetched details to a metal part. Obviously, it won't work for anything load-bearing, but for stuff like nuts, it's amazing. Just brush on a bit, it's fully transparent so won't be visible, position your tiny part, then after it dries a bit - brush a bit more to fully seal. No mess, plenty of workable time.
Happy building :-)
#56 Posted : 24 July 2017 21:05:15
That's useful to know Michal. I have used paint or varnish in the past, which is very similar to what you suggest and which works well if, as you say, there is no load on the part. 'Formula 560' canopy glue is also quite good and cleans up with water, and also 'Microscale' Metal Foil Adhesive, which is pressure activated and leaves no messy edges to tidy up? Nowadays, I tend to just use thin CA glue picked up along the edge of a scalpel blade which can then be touched to the edge of a part letting capillary action suck it in and around a joint, and then sprayed with an 'accelerator' to cure it instantly, but your method does work very well and I suspect that being a metal (etching) primer it may have some slight benefits in attaching to metal better than normal paint or varnish would?
Thanks for your input Michal, much appreciated. Cool ThumpUp
michu
#57 Posted : 24 July 2017 21:15:03
Kev, if you have a look in my MP4/6 build diary and look very close at the driveshafts, you will see how well it works. The thin strip of bare metal around the cuff is not a separate part, but just a ridge machined onto the metal cuff. I painted the whole thing black, varnished to have the right level of flatness, and then scraped the paint from the ridge around the part. Now if you look very close, there is a tiny p/e part visible on that ridge on one of the shafts. It's a tiny rectangle, maybe 1mm by 0.5mm which is glued on top of the ridge. Which is round. I see no way I could pull it off with superglue because of how tiny and light the part is - slightest touch tended to turn it out of alignment, so it was positioning across instead of along the ridge, or was knocked out of it completely. So the metal primer to the rescue - it gave me enough time to put the part in place by gently prodding with a tip of 10/0 brush. And now why I'm writing about it: the joint is so positive, that this assembly survived all that paint scrapping without any issues. Frankly I'm pretty sure it's stronger than it would be if done with CA glue thanks to the fact I could use the primer under, over and around the tiny part.
Happy building :-)
#58 Posted: : 27 July 2017 20:15:50
Seems a very sound method Michal and those little pieces of PE on your MP4/6 driveshafts do look to be well attached. I have some of that Mr Metal Primer myself and will be trying it on some of the tiny PE parts on my 1:20 MP4/4 build to see how well it holds.
Thanks for the tip. Cool ThumpUp
#59 Posted : 28 July 2017 21:26:25
Hello all,
Made some more progress on this build, quite a few bits done in fact but not all of it painted and finished yet so I'll just show some of it here and save the rest for the next update.
Submerged the brass wheel nuts in some 'Krick' blackening fluid until they were the right shade of black as can be seen in the first two photos below.
Then primed and painted the gearbox/driveshaft couplings which come in the upgrade set as machined aluminium with a small etched part for each. Very tricky to mask and paint such small parts neatly so forgive me if they aren't perfect but they won't be easily seen when the rest of the suspension and engine fittings are surrounding them.
The main engine/gearbox/lower suspension assembly shown as primed in my last update was then sprayed black and then masked up to leave the gearbox exposed which was then sprayed gunmetal. It should be titanium but the gunmetal was a little darker and looked more in line with my reference photos so gunmetal it is! I then fitted the gearbox/driveshaft couplings to the gearbox along with an etched ring that surrounds each coupling and which was painted in an anodised colour to match my reference photos.
The resin upper suspension assembly was then sprayed black and the top fittings for the springs were also painted and added inside the wishbones. These have already been fitted to the gearbox and I have done more fitting of parts to the engine/gearbox along with some more to the brakes/calipers but the photos for that work will be shown in the next update.
#60 Posted : 29 July 2017 09:05:24
An amazing amount of detail at such a small scale, looks great Cool
7 Pages <12345>»
This page was generated in 0.246 seconds.
