plank lengths Options
vindiboy57
#1 Posted : 09 February 2011 21:26:06
any of you guy out there know, or have a rough idea how long the hull planks are as i am second planking (just to hide the mistakes on the first) to make it look more authentic THANKS
#2 Posted : 09 February 2011 22:18:04
errrrr,not sure what you want to know,?are you veneering the second coat?if so you can go the whole length of the hull,you will need 75 x 5mm. x .05mm.or .06mm. x 1000mm.what ever veeneer takes your fancy,I used mahogany on mine,others have used maple,cherry,walnut,the choice is yours,hope this helps you decide.
Mike Turpin
#3 Posted : 09 February 2011 23:11:11
Planks on the real ship were typically about 30 feet long. This scales out to approx 11 cm if I have got my sums right.
Mike T
RussG
#4 Posted : 10 February 2011 09:32:01
Mike T
Yep Mike I get it to that as well, roughly the lenght of the planks being supplied by De-ago, Just spent another 7 hrs on the lower hull Cursing when will it end, then I'm second planking but only the upper half as the bottom is going to be in copper, when they let us know, hopefully soon, what the arrangements will be , I recon about 2000 of them!!
Russ
Happy Building, Russ
On the workbench: My Victory Build Diary - Victory Cross Section Build Diary - Black Pearl Build Diary
Under the Bench: Millenium Falcon, Black Pearl x 2, Coral Victory Cross Section, De Lorean
One eye
#5 Posted : 11 February 2011 00:35:17
Rank: Amateur level 2
Angry Nearer 2,800+; then having to allow for cutting and trimming.
Numerous issues for 'Scale and match' to original fitting of copper sheathing, but this is a scale model - depends on your choice. Options are:
1. Purchase from De Ag at their rate per 100 tiles - who knows what scale/size and what price. If they decide to go for the tile route (other possibilities are tape and paint)
2. Purchase from Cornwall Model Boats - at your own choice (mine is not to touch them with a barge pole - let me explain below). 2a. Last Summer they offered these items - at a scale of 1/72 from £2.30 per pack of 100 tiles - now they are £7.20 per pack. Supply and demand; or RIP OFF.
3. Look elsewhere, and get them cheaper.
4. Don't copper the hull.....
I don't mind paying for quality goods, at the right price. I do object to getting ripped off.
My Hull will be copper tiled/plated, but I have a source at a reasonable price from the other side of the country, and will be bu**ered if I will now put any of my hard earned cash towards a Kernow Pirate.
As a footnote; Tomick stated that 1/72 is way to big (scale wise) for copper hull plates/tiles. He is correct. However, the cannons are not as acurate as they should be, the gun ports are the wrong size - and in several upper deck locations, in 'slightly' the wrong place - and the whole model is subject to change without notice...
This is not Tomicks decision, just his masters....
I an happy with reasonably priced 1/72 copper hull tiles at an additional total cost of £67.00, as opposed to CMB recently upgraded price of over £200.00. What will De Ag offer us? Karl has an idea...
See ya.
Mike Turpin
#6 Posted : 11 February 2011 01:06:44
One Eye
You are presenting a somewhat distorted view of what CMB are selling. If you follow your own advice and look elsewhere BUT on the CMB website, you will find that they do supply packets of 100 copper plates at various prices depending on size and at prices in the £2.50 region.
The problem with the DEAG Victory is that there are no plates that I am aware of to a scale of 1/84, the nearest are probably the 1/72 scale supplied by Caldercraft and obtainable at CMB for £2.40 per 100, including the increased VAT.
Let me make it perfectly clear that I have no connection with CMB other than as a satisfied customer over a period of years and don't like to see a business wrongly given a bad name.
BTW your estimate of 2800 may be below the real figure if you also decide that as well as ensuring a realistic scale size, you choose to correctly overlap the plates to achieve a single rivet line on each join as would happen on a real shipo of the time.
Mike T
#7 Posted : 11 February 2011 10:31:34
hi mike,I'm sorry mate,but I have to disagree with you on the service record of cmb,My experiance over the woodlathe has tainted my opinion of them,I am still fighting them over my return of the totaly in adiquate goods,that were not fit for the job,other materials that I bought were up to the job,and delivery was good,but beware there is no cummunication by e_mail and there telephone manner needs a lot to be desired,there web site doe's not tell you if they are out of stock,so you have to wait sometimes for up to two weeks for a delivery.btw I ended up buying the proxxon lathe model 250,and what a difference,totaly suited to the job it is meant to do.brilliant and would reccomend to anyone.
Mike Turpin
#8 Posted : 11 February 2011 15:45:12
Hi Karl
We all have different experiences -- I have been in regular e-mail contact over a very small mistake made in my last order which has been simply sorted out.
BTW I think both Tomick and I were recommending the Proxxon 250 all along. It really does the job well doesn't it?
Mike T
#9 Posted : 11 February 2011 16:10:56
The major difference being that the Proxxon lathe is 240v, whereas the Mantua lathe is 12v.
One eye, I might clarify that I'am not the designer of the model, I simply build as per that being supplied to the customer, I simply pointed out that 1/72 scale tiles are too large for a 1/84 model, Any model is a personal item and its down to personal choice as to any changes made, if one is happy with the end result then who is anyone to argue.
As far as I know the DeAgostini copper tile pack will contain scale tiles and sold as a complete pack rather than by the cost of 100 tiles.
One eye
#10 Posted : 12 February 2011 01:18:16
Hi Tomick
Thank you for the clarification. I do realise that you had no input in the design of the model, as it is apparent that on occasion you are in the dark as much as the rest of us regarding future elements of the build. I also pointed out that you were correct regarding the 1/72 scale tiles; and then clarified everything by pointing out that none of this was your decision, but that of your masters. We all have masters who dictate or control our way of working. Mine is called the MD.
Apologise if you took offence, but none was ment, nor delivered.
Carry on the great work, coz you are the inspiration to us all. I just wish I had the time to keep up with your diary, but work etc, etc. Only as far as the fairing, which has taken several weekends to perfect, because I realise the importance of the finished hull.
See Ya. Wink
One eye
#11 Posted : 12 February 2011 02:17:50
Mike Turpin wrote:
One Eye
Mike T
Hi Mike T
I have appreciaed your knowledge and input on this forum since day one. I am also pleased that you have no affiliation with CMB.
I understand the coppering of ships of the line in the 18th century, and also realise that this is impractical to replicate on scale models. All we are after is to acheive a representation of a coppered hull. To suggest that you may want to overlap the tiles, as originally installed is perfection, boardering on insanity. You can get Port and Starboard tiles to replicate this - as you know, but most of us will settle for the 'tiled/brickwork' finish without the need for microscopic detail.
My post was to assist Russ G, and other members of this forum, as to the possible number of copper tiles which may be needed to complete the job on this 1/84 model. I am sure you are aware that in 1780 HMS Victory was first sheathed in 3,923 copper plates of 4' x 14". My suggestion of 2,800+ was an indication, and also noted addditional requirement for cutting and trimming. If using 1/72 scale tiles on a 1/84 scale model, then we arrive at approx 3,300 tiles - based on the actual ship, and not our individual model, which will have major variances in comparison to the lines of the actual hull.
Finally, I had forward planned the coppering aspect of this build, and had checked CMB's price for copper tiles last summer. The same pack of 100 photo etched Amati 1/72 tiles has increased to £7.20 - exc VAT. There are cheaper alternatives, and we have now given everyone a nice alternative in Caldercraft. Thank You.
PS. If you pay attention to detail, you will note that I did take my own advice, and found a source at a reasonable price at the other end of the country, via a very nice model shop which I can pop into at my leisure (Caldercraft).
See ya. Wink
This page was generated in 0.155 seconds.
