 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
the part in place. stevegbr attached the following image(s):
another vehicle, which is called the laser cutter. stevegbr attached the following image(s):
yes that is the pod lock system ;) really great how they did it
ElekTr1C wrote:yes that is the pod lock system ;) really great how they did it thought it was, very clever.
here is part 43, which includes the motor and gears. stevegbr attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,195 Points: 15,734 Location: ipswich
Please, please - come to the UK...
here is the motor and screws and two gears. stevegbr attached the following image(s):
here is the motor secured by three screws at the front of thunderbird 2. stevegbr attached the following image(s):
next, the two gears are put on the pivot pin on each end. stevegbr attached the following image(s):
the front panel is now put back in place. stevegbr attached the following image(s):
putting the plastic racks on to the spring steel rods for the legs. stevegbr attached the following image(s):
here is part 44, this is the guide rail for the legs. stevegbr attached the following image(s):
Nice update Steve  really taking shape now. Al
thanks al.
guide rail and screws, and limit switch. stevegbr attached the following image(s):
guide rail in place on the body. stevegbr attached the following image(s):
this part 45, which contains is the other side channel. stevegbr attached the following image(s):
this is the next channel to be fitted. stevegbr attached the following image(s):
part 46, which contains the clear covers for the spring legs. stevegbr attached the following image(s):
in each of the spring legs a tiny pin as to be inserted so the legs can be leaned over, passed the middle cog, then the plastic gear strip is in line with the gear, then the cover is placed on top and secured with screws. stevegbr attached the following image(s):
Guest (5)
