33 Pages «<1112131415>»
Deagostini 1/144 Thunderbird 2 Build (stevegbr) Options
stevegbr
#241 Posted : 13 January 2017 15:53:49
the part in place.
stevegbr
#242 Posted : 13 January 2017 16:22:06
another vehicle, which is called the laser cutter.
ElekTr1C
#243 Posted : 13 January 2017 17:45:02
yes that is the pod lock system ;) really great how they did it
stevegbr
#244 Posted : 13 January 2017 17:48:41
thought it was, very clever.
stevegbr
#245 Posted : 13 January 2017 18:14:41
here is part 43, which includes the motor and gears.
#246 Posted : 13 January 2017 18:32:48
Please, please - come to the UK...
stevegbr
#247 Posted : 13 January 2017 21:38:00
here is the motor and screws and two gears.
stevegbr
#248 Posted : 13 January 2017 21:39:42
here is the motor secured by three screws at the front of thunderbird 2.
stevegbr
#249 Posted : 13 January 2017 21:41:37
next, the two gears are put on the pivot pin on each end.
stevegbr
#250 Posted : 13 January 2017 21:42:39
the front panel is now put back in place.
stevegbr
#251 Posted : 13 January 2017 23:30:55
putting the plastic racks on to the spring steel rods for the legs.
stevegbr
#252 Posted : 13 January 2017 23:32:13
here is part 44, this is the guide rail for the legs.
#253 Posted : 13 January 2017 23:59:03
Nice update Steve Cool really taking shape now.
stevegbr
#254 Posted : 14 January 2017 00:10:17
thanks al. BigGrin BigGrin
stevegbr
#255 Posted : 14 January 2017 00:13:51
guide rail and screws, and limit switch.
stevegbr
#256 Posted : 14 January 2017 00:14:39
guide rail in place on the body.
stevegbr
#257 Posted : 14 January 2017 12:33:04
this part 45, which contains is the other side channel.
stevegbr
#258 Posted : 14 January 2017 12:34:22
this is the next channel to be fitted.
stevegbr
#259 Posted : 14 January 2017 12:36:06
part 46, which contains the clear covers for the spring legs.
stevegbr
#260 Posted : 14 January 2017 12:39:00
in each of the spring legs a tiny pin as to be inserted so the legs can be leaned over, passed the middle cog, then the plastic gear strip is in line with the gear, then the cover is placed on top and secured with screws.
Guest (5)
This page was generated in 0.318 seconds.
