Keel fitting before planking? Options
saintsman123
#1 Posted : 05 February 2011 18:58:56
I've been looking around various diaries on here and MSW, I see quite a few modellers fit the keel before planking,like Magpies Surprise, I did wonder about this with Victory, but have followed the mags. Now as I am thinking of getting another model and would probably like to fit the keel first as you can then trim the planks to the actual size. Is this the more customary thing to do or does it purely have to do with the particular model.
Come on you Jimmies
#2 Posted : 05 February 2011 21:13:30
Its down to kit design and model type, some kits utilise a false keel as also being the real keel, some kits start with adding the real keel to the false keel then adding the frames/planking.
In our instance as you know, the real keel is added to the false keel after the model has been planked, which is what the kit designer/manufacturer Artesania Latina recommend.
In our instance the real keel is 6mm wide whilst the false keel is 4mm wide, so there is an immediate centering alignment of the real keel to overcome, which is why the build format is as it is, with the real keel being added after the hull has been planked and a real keel central alignment slot made.
There's nothing stopping you from stepping outside of the instructions and doing your own thing, but should your build then go wrong, your then own or on the reliance of others to sort out the problem, a novice should stick with the intended build which in theory has been worked out to avoid pitfalls.
saintsman123
#3 Posted : 07 February 2011 15:20:43
Thanks Tomick, it was just something I had wondereed about, especially when you see the "double plankers" planking up to the keel, and had noticed it on some other model builds. Thanks again
Come on you Jimmies
This page was generated in 0.104 seconds.
