2 Pages <12
Tunk's build Options
tunko
#21 Posted : 06 January 2017 02:00:46
Rank: Amateur level 2
I have finally plopped together my scratch-built equipment bay. I wish my detailing skills were better, but it looks OK from a distance. Pictures follow.
tunko attached the following image(s):
dwayneg
#22 Posted : 06 January 2017 02:32:14
ThumpUp Tunko, This great, I wish I had more time to work on mine. Keep it going.
Tamiya 1/32 P-51D, Revell 1/32 Bf 109G-6 x2 1/32 P-51B, 1/32 Trumpeter Bf109K-4, 1/32 Hasegawa Bf 109E, Testors 1/32 F-117, RMF 1/35 Tiger 1
A Thumbs
#23 Posted : 06 January 2017 15:33:54
Looks awesome! Can't wait to see it installed! What's the flooring made of?
tunko
#24 Posted : 06 January 2017 20:26:11
Thanks for the encouragement. The floor is self-adhesive vinyl screen patch kit, cut to shape and stuck to a polystyrene sheet.
#25 Posted : 06 January 2017 23:22:33
Excellent piece of work, looks brilliant. ThumpUp
Bill-Devine
#26 Posted : 09 January 2017 23:28:43
looks good to me keep up the good work
Make things as simple as possible but not simpler... - Albert Einstein
tunko
#27 Posted : 29 June 2017 18:16:44
I finally received my final issues, and have started adding the details to the engine bay cover. I discovered that the instructions are very misleading. After getting confused about the apparently inconsistent placement of a couple of parts, I decided to use the photos of the real model as an additional guide. Wow. The installation instructions for many of the greeblies are incorrect (especially regarding orientation) and are inconsistent with the finished diagram. Not only that, but the instructions and the finished diagram do not match the original model. Has anyone else noticed this?
gedmac66
#28 Posted : 20 August 2017 15:30:16
Any further updates coming soon ?
tunko
#29 Posted : 12 October 2017 13:33:46
Thanks for the interest! I had to pack my build in the basement for a few weeks because we had visitors and needed the room.
I crushed my Paragrafix cockpit when packing it up :(
But I'll post soon. I have been spending some time using an Arduino to drive some Neopixels as engine replacement.
And I'm debating how much more time to spend customizing the interior...
tunko
#30 Posted : 11 September 2018 18:17:42
I am back on track with my Falcon build. I have attached the scratch-built equipment bay to the cargo hold. I had to make an extension for the corridor because the corner was too tight. The 3D printed piece fit first try!
#31 Posted : 11 September 2018 18:27:10
tunko
#32 Posted : 11 September 2018 18:28:28
I also stumbled upon these boys here while debugging some electronics - I thought they were perfect for the Falcon. They are snap-on ferrite beads for suppressing RF noise in cables. Remove the ferrite part and they make fantastic cargo containers. Any they open too! The Shapeways 3D printed container is in the middle for size comparison.
#33 Posted : 11 September 2018 21:56:52
That’s some excellent work you are doing. Some clever ideas.
2 Pages <12
