Joined: 04/06/2010 Posts: 332 Points: 1,000 Location: Bannockburn
Stage 74 - The left pillion footrest Parts supplied: Pillion footrest bracket, Pillion footrest, Pillion footrest pivot, Pillion footrest rubber, Screw hole cover (left), Screw hole cover (right) and Scews Also required: Main frame assembly (Stage 73) bugsec attached the following image(s):
Stage 75 - The right pillion footrest: Parts supplied: Pillion footrest bracket, Pillion footrest, Pillion footrest pivot, Pillion footrest rubber and Screws Also required: Main frame assembly (Stage 74) bugsec attached the following image(s):
Stage 76 - The seat base Parts supplied: Seat base, Seat hinge A, Seat hinge B and Screws Also required: Main frame assembly (Stage 75) bugsec attached the following image(s):
Pack 24 - Stages 77 - 80 Stage 77 - The seat Parts supplied: Seat Also required: Main assembly (Stage 76) bugsec attached the following image(s):
Very nicely built Graham, looks cool, especially with the lights working - well done.
I notice in one of your photos that the front tyre has some white 'blooming' on it's surface? Not sure if you already know but it just needs a light wipe with some silicone oil to revert it back to a nice clean rubber look. Hope that helps?
Kev
Stage 78 - The left mirror Parts supplied: Left mirror Also required: Main assembly (Stage 77) Like some others had a slight issue with the the hole for the mirror being D shaped and the mirror itself round but soon resolved by modifying the D shape to be an O shape. bugsec attached the following image(s):
Stage 79 - The right mirror Parts supplied: Right mirror Also required: Main assembly (Stage 78) bugsec attached the following image(s):
Stage 80 - The base plate Parts supplied: Base plate, Speaker frame and Speaker grille Also required: Main assembly (Stage 79) and Display base (Stage 73) bugsec attached the following image(s):
ModelMania wrote:Very nicely built Graham, looks cool, especially with the lights working - well done.
Kev  Hi Kev Thanks for looking in. I have seen the tip on restoring the tyres just need to get some silicone oil. Graham
bugsec wrote:ModelMania wrote:Very nicely built Graham, looks cool, especially with the lights working - well done.
Kev  Hi Kev
Graham Oh OK, wasn't sure if you knew Graham, but that's cool. Glad you'll be able to sort it, the bloom spoils the rest of what looks like an excellent build. We had the same problem with the tyres on the 1:8 McLaren MP4/23, but easily rectified with some oil. Well done.
Kev
Looks good Graham, nicely done.... Regards Alan
Very nicely done Graeme
Hi looks great.there superb models when complete.I used silicone oil on my tyres they come up a treat.I used the stuff they do motor cycle helmit rubber seals with.can get it anywhere that sells bikes.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Superb work Graham  she's a credit to you, well done. Al
 Great job on her Greame Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
A very fine model indeed! Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Great job, a beautiful build.
Thanks all for the kind comments. Finally got round to sorting out the front tyre and it does look much better now. bugsec attached the following image(s):
Yep she does Al
 Rank: Semi-Pro Level 2   Groups: Registered
Joined: 20/02/2012 Posts: 83 Points: 249 Location: Midlands
Nice job done Graham. BUILDING - HONDA CB750 - HAYNES V8 VISIBLE ENGINE
NEXT BUILD - JAGUAR E-TYPE
GEOFF
