8 Pages «<5678>
Graham's CB750 Build Options
bugsec
#121 Posted : 05 January 2017 20:28:58
Stage 74 - The left pillion footrest
Parts supplied: Pillion footrest bracket, Pillion footrest, Pillion footrest pivot, Pillion footrest rubber, Screw hole cover (left), Screw hole cover (right) and Scews
Also required: Main frame assembly (Stage 73)
bugsec attached the following image(s):
bugsec
#122 Posted : 05 January 2017 20:30:30
Stage 75 - The right pillion footrest:
Parts supplied: Pillion footrest bracket, Pillion footrest, Pillion footrest pivot, Pillion footrest rubber and Screws
Also required: Main frame assembly (Stage 74)
bugsec
#123 Posted : 05 January 2017 20:31:31
Stage 76 - The seat base
Parts supplied: Seat base, Seat hinge A, Seat hinge B and Screws
Also required: Main frame assembly (Stage 75)
bugsec
#124 Posted : 05 January 2017 20:33:59
Pack 24 - Stages 77 - 80
Stage 77 - The seat
Also required: Main assembly (Stage 76)
#125 Posted : 05 January 2017 20:34:36
Very nicely built Graham, looks cool, especially with the lights working - well done. Cool ThumpUp
I notice in one of your photos that the front tyre has some white 'blooming' on it's surface? Not sure if you already know but it just needs a light wipe with some silicone oil to revert it back to a nice clean rubber look. Hope that helps? ThumpUp
bugsec
#126 Posted : 05 January 2017 20:34:45
Stage 78 - The left mirror
Parts supplied: Left mirror
Also required: Main assembly (Stage 77)
Like some others had a slight issue with the the hole for the mirror being D shaped and the mirror itself round but soon resolved by modifying the D shape to be an O shape.
bugsec
#127 Posted : 05 January 2017 20:35:56
Stage 79 - The right mirror
Parts supplied: Right mirror
Also required: Main assembly (Stage 78)
bugsec
#128 Posted : 05 January 2017 20:36:58
Stage 80 - The base plate
Parts supplied: Base plate, Speaker frame and Speaker grille
Also required: Main assembly (Stage 79) and Display base (Stage 73)
bugsec
#129 Posted : 05 January 2017 20:39:52
Hi Kev
Thanks for looking in. I have seen the tip on restoring the tyres just need to get some silicone oil.
Graham
#130 Posted : 05 January 2017 20:51:14
Hi Kev
Graham
Oh OK, wasn't sure if you knew Graham, but that's cool. Glad you'll be able to sort it, the bloom spoils the rest of what looks like an excellent build. We had the same problem with the tyres on the 1:8 McLaren MP4/23, but easily rectified with some oil. Well done. Cool ThumpUp
#131 Posted : 05 January 2017 21:46:33
Looks good Graham, nicely done....Cool Cool
#132 Posted : 06 January 2017 00:05:18
Very nicely done Graeme ThumpUp
#133 Posted : 08 January 2017 14:12:54
Hi looks great.there superb models when complete.I used silicone oil on my tyres they come up a treat.I used the stuff they do motor cycle helmit rubber seals with.can get it anywhere that sells bikes.cheers mick. BigGrin
#134 Posted : 08 January 2017 17:10:00
Superb work Graham ThumpUp she's a credit to you, well done.
#135 Posted : 08 January 2017 17:55:37
BigGrin Great job on her GreameCool
#136 Posted : 09 January 2017 18:22:42
A very fine model indeed!
#137 Posted : 09 January 2017 22:13:43
Great job, a beautiful build.
bugsec
#138 Posted : 22 January 2017 12:09:56
Thanks all for the kind comments.
Finally got round to sorting out the front tyre and it does look much better now.
#139 Posted : 22 January 2017 19:12:13
Yep she does Cool
Geoff44
#140 Posted : 22 March 2017 17:25:51
Nice job done Graham. Cool Drool
BUILDING - HONDA CB750 - HAYNES V8 VISIBLE ENGINE
NEXT BUILD - JAGUAR E-TYPE
GEOFF
8 Pages «<5678>
This page was generated in 0.244 seconds.
